Page 2 of 3 1 2 3
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481778
04/12/18 06:48 PM
04/12/18 06:48 PM
SC304 Offline
SC304  Offline
I'm going out on a limb here that the 6.1 block used in that build was the older version.
The new version we use in the super charged combo is not available with lifter locations to support a 6.1 cylinder head configuration. Not yet anyway it is in the master plan just further down the list.
Mike
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: SC304] #2481795
04/12/18 07:32 PM
04/12/18 07:32 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Mike
That's the picture you gave us in my other post?
The lifters are not in the stock location.
R U saying production heads won't work?
Matt
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481851
04/12/18 10:09 PM
04/12/18 10:09 PM
jersey
Spaceman Spiff Offline
jersey
9.55 with 700 horsepower.
i'm guessing the " factory stock" rules are pretty liberal when it come to weight reduction.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: Spaceman Spiff] #2481896
04/12/18 11:13 PM
04/12/18 11:13 PM
gregsdart Offline OP
Scienced out race car, 3200 lbs shipped. Radial slicks. Wallace calculater says 726 hp, and that is probably based on bias tires and less efficient trans.
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: MattW] #2481919
04/13/18 12:01 AM
04/13/18 12:01 AM
SC304 Offline
SC304  Offline
I showed a few pictures in my earlier post.
One had lifters in stock location none of the raised X webbing in cam tunnel area.
Other has the heavy bracing and obvious lifter relocation.
You will have a hard time bolting older heads onto the newer relocated lifter config.
The rocker gear is not stock in the newer heads as you might think.
Again they will get around to providing the new casting with a standard lifter location and the older heads will all fit and pushrods and rockers won't be an issue.
My FS/D stocker has a minimum weight of 3370 with driver as a 392 combo. This combo uses the 6.1 block with cnc'd Apache heads and T&D rockers which requires machining of the head. I believe our best pass at Indy last year was 9.37.
Mike
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2481968
04/13/18 01:41 AM
04/13/18 01:41 AM
New York
polyspheric Online content
polyspheric  Online Content
New York
Never mind
Boffin Emeritus
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2482003
04/13/18 07:49 AM
04/13/18 07:49 AM
jersey
jersey
A new challenger that weighs 3200 is far from “ factory stock”.
What dealer can a purchase a new 3200lb challenger at?
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: Spaceman Spiff] #2482031
04/13/18 09:56 AM
04/13/18 09:56 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Wow !!!
Your not serious?
Matt
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2482078
04/13/18 11:42 AM
04/13/18 11:42 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FYI they are RACECARS not streetcars. They are race by racers not your average Joe either. They understand how to get everything out of what they have HP wise, something the average guy is not even close on nor would want to spend the money on. It aint hard to get weight out of cars at all, especially production cars.
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2482085
04/13/18 11:53 AM
04/13/18 11:53 AM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
Anybody know how light you can build a challenger before adding a fiberglass body parts(doors, fenders, etc)?
Adriel Paradise
Substation Design Engineer III
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2482094
04/13/18 12:12 PM
04/13/18 12:12 PM
Body in white as a start, moly, maybe 2800? Just a guess.
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: polyspheric] #2482097
04/13/18 12:17 PM
04/13/18 12:17 PM
Originally Posted By polyspheric
You need to think in three dimensions i.e. a trussed design
Of course, why didn't I think of that?
The trick is how to get those very substantial trusses in between the main bearing bulkheads, between the head bolts, between the cylinder sleeves, and inside the main caps.
An aluminum block as stiff as cast iron is impossible.
Theory is fine, but a real engine development program ON THAT PARTICULAR ENGINE trumps theory
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2482105
04/13/18 12:33 PM
04/13/18 12:33 PM
New York
New York
Let me guess: "you delete your posts because you know you're wrong!"
So funny!
Boffin Emeritus
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2482182
04/13/18 02:43 PM
04/13/18 02:43 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I think what poly is getting at (and he can correct me if I wrong) is anything you do to an Al block to make it sturdier can also be done to an iron block to make it sturdier and in the end the iron will be sturdier. You can't compare a steel gas can to an aluminum iceberg. Had the iron block had HSS cylinder liners, ribs over the cam tunnel area... it may have made more HP.
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2483284
04/15/18 09:12 PM
04/15/18 09:12 PM
I get such a charge out of people that can't accept the posibilty that what i wrote about has been done. I used to think that way sometimes, 45 years ago.
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2483344
04/15/18 10:42 PM
04/15/18 10:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
New Gen 3 powered Challengers will easily go down to less than 3200 with factory body and interior panels. All that and power windows.
Doug
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2483544
04/16/18 12:24 PM
04/16/18 12:24 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Come now Greg, we all know theory is way more important than practical application. Some people cling to old theories and ways of thinking. It is one of the largest factors that to this day still holds back Mopar guys.
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: Al_Alguire] #2483589
04/16/18 01:54 PM
04/16/18 01:54 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
No truer words have ever been posted on Moparts. As a whole we are our own worst enemy.
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2483708
04/16/18 04:52 PM
04/16/18 04:52 PM
My hero, Bob Glidden, said in an intervue,
"We are all idiots, the guy that trys the most stuff wins"
Bob averaged 95 hours a week trying things to go faster, from what i heard. I am betting he most always thought outside the box.
Re: Gen III AL block, big power gain! Ma Mopar paying racers! [Re: gregsdart] #2483726
04/16/18 05:16 PM
04/16/18 05:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Most TRUE innovation in the world comes from trial and error....
Page 2 of 3 1 2 3
