Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2489290
04/29/18 12:08 AM
04/29/18 12:08 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
That's what I figured, but I did look up and the OD of the bearing is supposedly the same. I'm wondering if new axles with green bearings would work. I guess I'll contact Dr. Diff next week when he's back from MATS.
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2489403
04/29/18 10:26 AM
04/29/18 10:26 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
IIRC dosent the dr have a conversion for them.I know he makes something to change the rears.Rocky
Chrysler Firepower
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2489635
04/29/18 07:06 PM
04/29/18 07:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The housing end bolt pattern changed in '62. Some folks over on the FL forum have mounted the later brake backing plates by drilling new holes and using aftermarket axles with Green bearings.
The bearing race diameter is the same but the flange axle bearing collar hits the inner seal in the taper axle housing. The Greens need no inner seal.
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2489774
04/30/18 12:04 AM
04/30/18 12:04 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
They drill new holes in the housing flange? I suppose that wouldn't be too difficult...
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2490075
04/30/18 05:54 PM
04/30/18 05:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
No, they drill the backing plate.
I tried to find the thread with pics but their search only goes back one year.
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2490103
04/30/18 07:18 PM
04/30/18 07:18 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
They have axles with the correct flange for the early axle ends?
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2490148
04/30/18 09:58 PM
04/30/18 09:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Dont no about 57 but the 66 and up axles fit the 62-65 housing. The problem is the housing is not machined deep enough to accept the seal and bearing together. I have used late axles with green bearings and no inner axle seal.
Doug
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2493074
05/07/18 04:14 AM
05/07/18 04:14 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If I remember correctly, you can't simply re-drill the bolt pattern on a newer backing plate as a 1957 housing end has a ROUND flange.
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2493163
05/07/18 12:55 PM
05/07/18 12:55 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Could be. I haven't looked that closely at it.
