Re: Identify this item coming thru firewall of '71 B Body
[Re: T2R9]
#2485291
04/19/18 09:50 PM
04/19/18 09:50 PM
Posts: 7,197 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
The throttle cable is above that next to the bulkhead connector. Is it a cruise control car? Looks like a cable of some sort. The hood release is on the other side of the brake booster/master. Correct, the throttle pedal lever is longer{higher up} than the hole in question..That hole is actually behind the throttle lever in action on the inside...
[Re: Fab64]
#2485542
04/20/18 12:12 PM
04/20/18 12:12 PM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
What does it go to inside the car ???
Nothing I love more than when someone repaints the engine compartment and leaves everything that wasn't there originally in place ... ugh
Mainstream Media is the new Pravda
[Re: JohnRR]
#2485599
04/20/18 01:49 PM
04/20/18 01:49 PM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
What does it go to inside the car ??? Unfortunately, I can't get inside the car right now. I'll check later today, I just thought someone might know. I'm guessing it's something to do with cruise control. I'll post it when I find out. Nothing I love more than when someone repaints the engine compartment and leaves everything that wasn't there originally in place ... ugh Yeah, bugs me too. My engine's currently out, so I'm going to try to clean up what I can.
[Re: Fab64]
#2485644
04/20/18 03:33 PM
04/20/18 03:33 PM
Fab64
So Cal, USA
Ok, got inside the car. Unfortunately, whomever removed it very crudely hacked it off inside. It's right above the accelerator pedal bracket, an electrical cable of some sort, still can't tell what it is:
[Re: Fab64]
#2485658
04/20/18 04:16 PM
04/20/18 04:16 PM
Posts: 16,189 Mesa, Arizona
dart4forte
Mesa, Arizona
Hi all,
1971 Satellite. Something else that a previous owner hacked off. This is coming thru the firewall, below the bulkhead connector. I haven't been able to find it in the manuals I have, and can't get into the interior of the car right now to see where it's coming from. Any ideas?
Roger I have the same grommet on my 68 GTS. It's the tach wire.
Abe Lincoln
[Re: Fab64]
#2485659
04/20/18 04:17 PM
04/20/18 04:17 PM
Posts: 5,141 East Aurora (Buffalo) NY
RoadRunner
Pull grommet out. Carefully pull remaining wire stub out. If its for the tach, the wire should be grey.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#2485667
04/20/18 04:28 PM
04/20/18 04:28 PM
dart4forte
Mesa, Arizona
Pull grommet out. Carefully pull remaining wire stub out. If its for the tach, the wire should be grey. I stand corrected. I looked at a wiring diagram and the tach wire goes through the firewall via the bulkhead connector and yes, its a gray wire. 69 and earlier had a grommet/wire that went through the firewall and it was gray.
Abe Lincoln
[Re: gtx6970]
#2485711
04/20/18 06:26 PM
04/20/18 06:26 PM
Fab64
So Cal, USA
I stripped some of the outer casing away, and there are 3 wires: Black, Green and Red. Looking at the wiring diagrams on pages 8-152 & 153, I don't see anything that matches. They also look like they're cloth-wrapped.
[Re: BcudaChris]
#2485723
04/20/18 06:56 PM
04/20/18 06:56 PM
Fab64
So Cal, USA
That's some big gauge wire. Was the car a service vehicle in a previous life? Not that I know of.
[Re: 71 Charger R/T]
#2485763
04/20/18 08:18 PM
04/20/18 08:18 PM
Posts: 489 Chilly Northern, Minn.
71 Charger R/T
Pages 8-152 & 153 are for Challenger (Rallye cluster). I think you want to be back at 8-165. Oops! yours might be different in a Plymouth manual. Mine is for the Dodge. Never the less..... It should be the same for '71 B-bodies.
