Re: Block heater, oil or water
[Re: rowin4]
#2486322
04/22/18 10:32 AM
04/22/18 10:32 AM
Posts: 4,206 New York
polyspheric
New York
True, but many have the ECM programmed to prevent WOT until water temperature is up.
Boffin Emeritus
[Re: rowin4]
#2486328
04/22/18 10:43 AM
04/22/18 10:43 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
On my old 426 wedge Dyno mule there was a 20+ hp difference between cold oil and hot oil using 15/40. Warm the oil.
[Re: quickd100]
#2486430
04/22/18 03:18 PM
04/22/18 03:18 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
On my old 426 wedge Dyno mule there was a 20+ hp difference between cold oil and hot oil using 15/40. Warm the oil. I did some oil temp testing on the first motor I dyno tested, I saw 8 HP gain from 130 F oil temps with straight 30 wt. oil to 170 F Later on I switch to 10w30Wt on a different engine and the same brand DTS dyno and saw 3 HP gain difference between 130F and 180 F On the next motor I built and dyno tested I switch to 5W20WT and saw no HP differences between 70F and 220 F oil temps
[Re: rowin4]
#2486556
04/22/18 09:26 PM
04/22/18 09:26 PM
polyspheric
New York
Hot water rises, the "thermosyphon" effect allowed some small engines to work with a radiator above the jacket, but no pump.
Boffin Emeritus
