Re: Identify this item coming thru firewall of '71 B Body [Re: 71 Charger R/T] #2485795
04/20/18 09:09 PM
04/20/18 09:09 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Originally Posted By 71 Charger R/T
Pages 8-152 & 153 are for Challenger (Rallye cluster). I think you want to be back at 8-165.
Oops! yours might be different in a Plymouth manual. Mine is for the Dodge.
Never the less..... It should be the same for '71 B-bodies. twocents
Yeah, I'm using the 1971 Plymouth Chassis Manual, and those two pages contain the engine wiring diagram for Barracuda and Satellite.
Re: Identify this item coming thru firewall of '71 B Body [Re: Fab64] #2485796
04/20/18 09:12 PM
04/20/18 09:12 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Page 8-181 in the accessory wiring section shows it in my 71 Plymouth manual.
Re: Identify this item coming thru firewall of '71 B Body [Re: 71 Charger R/T] #2485797
04/20/18 09:12 PM
04/20/18 09:12 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
That is definitely Cruise control wires! I took some pictures of mine. They are quite heavy gauge and reduce down to very light gauge inside the cabin after the connector and up the steering column. My originals had the canvas cover on them as well, that was deteriorated out near the servo, so I replaced with a harness off a '73 (the original had a red appearing wire) like yours, the '73 had different colors but that may have been just the way they aged. The FSM shows them to be yellow, black and dark blue but they appear to be yellow, black and green. here are some pics if I can do this right.....
Thanks, I think we have a winner! Not sure why my wires are different color, but this looks like what it is. The only part that is still on the car is the turn-signal lever, and I'm not going to try to restore everything else. I'm already into enough work trying to replace all the under-hood components of the A/C system. Thanks, everyone! beer
Roger
Re: Identify this item coming thru firewall of '71 B Body [Re: Fab64] #2485799
04/20/18 09:17 PM
04/20/18 09:17 PM
Chilly Northern, Minn.
71 Charger R/T Offline
If you need to get rid of that lever, I'll gladly take it off your hands! whistling
Re: Identify this item coming thru firewall of '71 B Body [Re: 71 Charger R/T] #2485828
04/20/18 10:31 PM
04/20/18 10:31 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
PM sent.
Re: Identify this item coming thru firewall of '71 B Body [Re: Fab64] #2486018
04/21/18 11:51 AM
04/21/18 11:51 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
And I'd be interested in that grommet if you aren't using it. I'd send you a plastic hole plug replacment.
Trying to put together a COMPLETE database of every Mopar grommet and bumper. Haven't seen this one before.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Identify this item coming thru firewall of '71 B Body [Re: 71TA] #2486107
04/21/18 03:57 PM
04/21/18 03:57 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
That would be great, I was going to look for something to replace the hole in the firewall. Do you need the diameter?
