Re: Whats The Best Way To Clean Off Gasket Material [Re: 71 FJ6 Charger] #248354
03/09/09 11:23 PM
03/09/09 11:23 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Ray Barton turned me onto this unreal, super-slick, $10 (USA) carbide scraper a few years back - nothing else comes close!
Rick
Re: Whats The Best Way To Clean Off Gasket Material [Re: Rick_Ehrenberg] #248355
03/09/09 11:37 PM
03/09/09 11:37 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
Rick
Looks like maybe a lathe tool insert or something like that...held on with a screw? Where can we get one?
Re: Whats The Best Way To Clean Off Gasket Material [Re: 375inStroke] #248356
03/09/09 11:50 PM
03/09/09 11:50 PM
NE Ohio
71 FJ6 Charger Offline OP
NE Ohio
Mopar recommends this on aluminum heads.
They are called Roloc discs and made by 3M.
Sweet,I have the green one of those,never thought of that!
'71 383HP FJ6 Charger SE
Re: Whats The Best Way To Clean Off Gasket Material [Re: DZJim] #248357
03/10/09 12:09 AM
03/10/09 12:09 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Rick
Looks like a grout removal tool for ceramic tile!
Tell me it isn't so!
Got any other pics of that?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Whats The Best Way To Clean Off Gasket Material [Re: 71 FJ6 Charger] #248358
03/10/09 08:09 AM
03/10/09 08:09 AM
Unfortunately back in New York
N
Nukechargerboy Offline
N
Careful when those nubs fly off, wear safety glasses.
Re: Whats The Best Way To Clean Off Gasket Material [Re: Nukechargerboy] #248359
03/10/09 12:18 PM
03/10/09 12:18 PM
Marlboro, NY, USA
Marlboro, NY, USA
It is made by Lisle, specifically made for removing gaskets. The carbide bit is held on by a screw, can be rotated / flipped to provide 6 total wear sufaces.
The debris kinda peels off and curls up cleanly, nothing will fly into your eye.
I found one souce online:
Lisle scraper
..I'm sure there are lots of others, most auto parts stores can order Lisle tools. I also swear by their "wrinkle band" ring compressor.
Rick
Re: Whats The Best Way To Clean Off Gasket Material [Re: Rick_Ehrenberg] #248360
03/10/09 02:43 PM
03/10/09 02:43 PM
The debris kinda peels off and curls up cleanly, nothing will fly into your eye. I found one souce online: url=https://www.penntoolco.com/catalog/products/products.cfm?categoryID=3666]Lisle scraper[/url]
Rick
Rick your recommendation is good enough for me. I am going to order one.
Re: Whats The Best Way To Clean Off Gasket Material [Re: RapidRobert] #248361
03/10/09 03:39 PM
03/10/09 03:39 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Rick
i just tried. I need a minimum order of $25. Any other cools tools on there for $15 or so??
Re: Whats The Best Way To Clean Off Gasket Material [Re: aarcuda] #248362
03/10/09 03:55 PM
03/10/09 03:55 PM
hooziewhatsit Offline
Looks like Northern auto tool has it also; a bit cheaper even. I don't know if they have a minimum order or not.
https://www.northernautoparts.com/ProductModelDetail.cfm?InventoryId=6953
Also has replacement heads for $5.
I think I'll have to pick one up as well.
Re: Whats The Best Way To Clean Off Gasket Material [Re: hooziewhatsit] #248363
03/10/09 04:15 PM
03/10/09 04:15 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
with Rug Trucker looks similar to a grout removal tool at home but no handle with bend. http://www.homedepot.com/webapp/wcs/stor...23X-_-100194652
Re: Whats The Best Way To Clean Off Gasket Material [Re: RapidRobert] #248364
03/10/09 04:54 PM
03/10/09 04:54 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Green 3M small disks. Really cleans the surface.
Re: Whats The Best Way To Clean Off Gasket Material [Re: snuggles] #248365
03/10/09 06:35 PM
03/10/09 06:35 PM
Rug_Trucker Offline
Rug_Trucker  Offline
Didn't I just say that?
Mopar Performance will repackage them and sell them for $21.95 No warranty, and probably won't fit!
Re: Whats The Best Way To Clean Off Gasket Material [Re: DZJim] #248366
03/10/09 08:42 PM
03/10/09 08:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Hmmm... Abrasive...aluminum oxide mds here
I guess if MOPAR says OK; however...
Forget what the MDS says , I use those to remove RUST off my firewall , the LAST place I would go near wit hsomething sporting ALUM> OXIDE as the cleaning surface is a MACHINED SURFACE ...
Re: Whats The Best Way To Clean Off Gasket Material [Re: Rug_Trucker] #248367
03/10/09 10:13 PM
03/10/09 10:13 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
I didn't see that earlier so I'll add an to my earlier post.
Re: Whats The Best Way To Clean Off Gasket Material [Re: snuggles] #248368
03/20/09 12:31 AM
03/20/09 12:31 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
From some Mopar TSBs:
Gasket Surface Preparation On Aluminum Engine Components
"NOTE: DO NOT USE METAL SCRAPERS GRINDING DISCS OR ABRASIVES TO CLEAN ALUMINUM ENGINE COMPONENTS. DAMAGE TO THE SEALING SURFACE WILL OCCUR."
Multi-Layer Steel (MLS) Head Gasket Installation Procedures
"Using a plastic or wooden scraper, scrape any large amounts of gasket residue from the surfaces. If necessary, apply additional solvent/gasket remover to ease removal.
If additional cleaning is needed, use a drill motor and 3M roloc bristle disc p/n 07528 (white) carefully remove remaining gasket material from head/block"
White is called fine by 3M, and they call yellow medium.
Personally, I would use any type of abrasive or power equipment as a last resort. At work, we use Plexiglas scrapers on everything, which us usually aluminum. Southwest Airlines wants only a specific scraper, which is a plastic softer than the Plexiglas, used on their aircraft. They tried using a cheaper maintenance company in Canada, and they used razor blades to remove seal on the skin. The entire plane had to be scraped. We got their business back after that.
Re: Whats The Best Way To Clean Off Gasket Material [Re: 71 FJ6 Charger] #248369
03/20/09 06:23 AM
03/20/09 06:23 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
3M roloc discs on a die grinder or drill works best.Thats all I use at home and work.Just use common semse when using them and they are great.Been using them for 20 years.Rocky
Chrysler Firepower
