Re: Whats The Best Way To Clean Off Gasket Material
[Re: Rick_Ehrenberg]
#248355
03/09/09 11:37 PM
03/09/09 11:37 PM
Posts: 247 DuPont, Washington
DZJim
DuPont, Washington
Ray Barton turned me onto this unreal, super-slick, $10 (USA) carbide scraper a few years back - nothing else comes close! Rick
Looks like maybe a lathe tool insert or something like that...held on with a screw? Where can we get one?
[Re: Nukechargerboy]
#248359
03/10/09 12:18 PM
03/10/09 12:18 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
It is made by Lisle, specifically made for removing gaskets. The carbide bit is held on by a screw, can be rotated / flipped to provide 6 total wear sufaces. The debris kinda peels off and curls up cleanly, nothing will fly into your eye. I found one souce online: Lisle scraper ..I'm sure there are lots of others, most auto parts stores can order Lisle tools. I also swear by their "wrinkle band" ring compressor. Rick
[Re: RapidRobert]
#248361
03/10/09 03:39 PM
03/10/09 03:39 PM
Posts: 15,493 the boonies
aarcuda
the boonies
It is made by Lisle, specifically made for removing gaskets. The carbide bit is held on by a screw, can be rotated / flipped to provide 6 total wear sufaces. The debris kinda peels off and curls up cleanly, nothing will fly into your eye. I found one souce online: url=https://www.penntoolco.com/catalog/products/products.cfm?categoryID=3666]Lisle scraper[/url] ..I'm sure there are lots of others, most auto parts stores can order Lisle tools. I also swear by their "wrinkle band" ring compressor. Rick
Rick your recommendation is good enough for me. I am going to order one.
i just tried. I need a minimum order of $25. Any other cools tools on there for $15 or so??
[Re: snuggles]
#248365
03/10/09 06:35 PM
03/10/09 06:35 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
looks similar to a grout removal tool at home but no handle with bend.
Didn't I just say that?
Mopar Performance will repackage them and sell them for $21.95 No warranty, and probably won't fit! ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: DZJim]
#248366
03/10/09 08:42 PM
03/10/09 08:42 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
Mopar recommends this on aluminum heads.
They are called Roloc discs and made by 3M.
Hmmm... Abrasive...aluminum oxide mds here
I guess if MOPAR says OK; however...
Forget what the MDS says , I use those to remove RUST off my firewall , the LAST place I would go near wit hsomething sporting ALUM> OXIDE as the cleaning surface is a MACHINED SURFACE ...
[Re: Rug_Trucker]
#248367
03/10/09 10:13 PM
03/10/09 10:13 PM
Posts: 8,964 Pizza Bucket
snuggles
Pizza Bucket
I didn't see that earlier so I'll add an to my earlier post. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: snuggles]
#248368
03/20/09 12:31 AM
03/20/09 12:31 AM
Posts: 1,547 Seattle, WA
375inStroke
Special needs person
Seattle, WA
From some Mopar TSBs: Gasket Surface Preparation On Aluminum Engine Components "NOTE: DO NOT USE METAL SCRAPERS GRINDING DISCS OR ABRASIVES TO CLEAN ALUMINUM ENGINE COMPONENTS. DAMAGE TO THE SEALING SURFACE WILL OCCUR." Multi-Layer Steel (MLS) Head Gasket Installation Procedures"Using a plastic or wooden scraper, scrape any large amounts of gasket residue from the surfaces. If necessary, apply additional solvent/gasket remover to ease removal. If additional cleaning is needed, use a drill motor and 3M roloc bristle disc p/n 07528 (white) carefully remove remaining gasket material from head/block" White is called fine by 3M, and they call yellow medium. Personally, I would use any type of abrasive or power equipment as a last resort. At work, we use Plexiglas scrapers on everything, which us usually aluminum. Southwest Airlines wants only a specific scraper, which is a plastic softer than the Plexiglas, used on their aircraft. They tried using a cheaper maintenance company in Canada, and they used razor blades to remove seal on the skin. The entire plane had to be scraped. We got their business back after that.
[Re: 71 FJ6 Charger]
#248369
03/20/09 06:23 AM
03/20/09 06:23 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
3M roloc discs on a die grinder or drill works best.Thats all I use at home and work.Just use common semse when using them and they are great.Been using them for 20 years.Rocky
Chrysler Firepower
