Page 2 of 3 1 2 3
Re: Battery under hood for race car [Re: AndyF] #2483099
04/15/18 03:02 PM
04/15/18 03:02 PM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
I run the Braille battery in my NSS car. The 17# only lasted about two years, so I went with the larger 21# this year.
1979 AMC Spirit, NHRA Q/SA
Re: Battery under hood for race car [Re: AndyF] #2483108
04/15/18 03:23 PM
04/15/18 03:23 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Challengers are in the spare tire well.
Re: Battery under hood for race car [Re: AndyF] #2483110
04/15/18 03:26 PM
04/15/18 03:26 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Some stocker guys put a master switch up front to shut the front battery off as well. 9.99 or quicker requires a shut off in the back, regardless where the battery is. The switch doesn't have to be back there. The shut off does so everyone knows where to look for it. It can operate the actual switch with a cable. Master switch is a safety device. I wouldn't have a race car without it. Especially with a lithium battery. I want everything off when the car is not being raced.
Not sure why a battery up front is any better than a battery in the rear with appropriate cables running up front to a set of terminals, studs or pass throughs.
Re: Battery under hood for race car [Re: moparx] #2483112
04/15/18 03:37 PM
04/15/18 03:37 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By moparx
Originally Posted By cudaman1969
On a stocker, a battery has to be in stock location, no disconnect is needed. Add a battery in the trunk, disconnect is manditory.
which begs this question. what about the "factory" location[s] on several newer cars with the battery in the trunk or under the rear seat ? disconnect mandatory even though this is a factory location[s] ?
beer
Only if another is added. Why? Can't remember NHRAs rational on this, maybe we can't make as good a battery box as the factory?
Shut offs have to be in the back of car so running two cables front to back would be, lets say, weird. Them wanting battery in stock location is to keep the car "stock appearing" only.
Re: Battery under hood for race car [Re: cudaman1969] #2483117
04/15/18 03:49 PM
04/15/18 03:49 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Originally Posted By hudsonhornet7x
Could any of these lithium batteries be used for a street/strip car? Lot's of street miles, say 3,000 per year.
Good question. A friend owns and runs an RV operation, sells these batteries. He has a ex pro mod Stattis (? spelling) with an 800 cu Chevy engine, he has two batteries (3x5x5), one for starting and one to run the electronics. No problems even with his previous Corvette race car whitch had them also. Just saying with the vibration and extreme conditions the race cars had-have, street driving should be a breeze.
Might add, he has a bank of these in his trailer to run lights and AC with solar panels on the roof to recharge. I was amazed how well they worked
What brand of battery?
Real Men shift for themselves
Re: Battery under hood for race car [Re: AndyF] #2483125
04/15/18 04:10 PM
04/15/18 04:10 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
All of the charger,magnum,300,Challenger have the battery in the rear. But it is factory so I am sure no disconnect is needed.
68 Barracuda Formula S 340
Re: Battery under hood for race car [Re: Bad340fish] #2483155
04/15/18 04:59 PM
04/15/18 04:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What is the largest lithium(CCA) that is reasonable
to buy
wave
Re: Battery under hood for race car [Re: AndyF] #2483278
04/15/18 09:10 PM
04/15/18 09:10 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Personally I think having a driver accessible power cut-off is a good safety feature. This could be accomplished with either a cable or continuous duty solenoid. With the solenoid it would only take a single ground circuit to the rear to control it. A second switch could be mounted in the driver compartment.
Doug
Re: Battery under hood for race car [Re: AndyF] #2483301
04/15/18 09:31 PM
04/15/18 09:31 PM
AndyF Online content OP
AndyF  Online Content OP
The ignition key is a pretty good power cut off that is driver accessible. If you want something that kills all of the power then that gets a lot more difficult. Especially with EFI and/or other electronic systems that don't want to be shut off hot.
I'd be interested to see how various folks are wiring up the EFI computers in race cars. Holley wants the ECU connected directly to the battery without a cutoff switch. I don't know if NHRA allows that or not. I suppose it depends on the tech person.
The car can be shut off by turning off the switched 12v to the ECU but the ECU is still connected to the BAT so there are still hot wires inside the car.
NHRA has never defined the master cutoff very well. The rules just say it should turn off the car but they don't say how much stuff can still be connected to battery power when the engine stops running.
Re: Battery under hood for race car [Re: CMcAllister] #2483306
04/15/18 09:39 PM
04/15/18 09:39 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Does the rule book specifically say if they battery is in factory location and the car is faster than 9.99 it requires a disconnect switch?
I don't believe it does. I just clarified this with a NHRA div 6 tech guy...quite a few hellcat Challenger/Chargers running 9's now with battery in the trunk in the factory location.
Re: Battery under hood for race car [Re: AndyF] #2483309
04/15/18 09:46 PM
04/15/18 09:46 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Rule book says "must stop all electrical functions". The only thing I ever have on the battery side of the master is the heavy wire running to the one wire alternator. Everything gets shut off.
Re: Battery under hood for race car [Re: AndyF] #2483348
04/15/18 10:45 PM
04/15/18 10:45 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Andy, go to the Painless Performance Products web site . click on accessories. PN# 50105 high output solenoid shut off. I think that could be wired into your key switch for total shut off.
Re: Battery under hood for race car [Re: CMcAllister] #2483381
04/16/18 12:03 AM
04/16/18 12:03 AM
That is true for a carb car. I don't think EFI cars are going to work that way. At least they don't if you follow the Holley instructions.
Re: Battery under hood for race car [Re: rowin4] #2483383
04/16/18 12:07 AM
04/16/18 12:07 AM
I don't think I need a cutoff switch since I'm not aiming for 9's and I have the battery under the hood.
I'm just going to use the key to shut things off. I'm also going to use a Ford type solenoid so the starter wire is only hot during cranking. I think that is pretty safe setup and should be NHRA legal for 10's.
Re: Battery under hood for race car [Re: AndyF] #2483438
04/16/18 02:18 AM
04/16/18 02:18 AM
missouri,usa
cryplydog Offline
cryplydog  Offline
missouri,usa
Andy, what p/n is the Ford type solenoid that you are going to use. I am aware that there are several different ones. I've been wanting to change the 64 over to the ford sol. thanks
Re: Battery under hood for race car [Re: cryplydog] #2483442
04/16/18 02:37 AM
04/16/18 02:37 AM
Finding the right solenoid has been a bit of an adventure. I started off with a typical Ford solenoid but then learned that I should use a diode suppressed solenoid to protect the ECU. So I got a diode suppressed one and then I figured out that I needed some way to make the neutral start function work. So now I'm shopping for a third solenoid. Good news is these things are cheap. I give my mistakes away to a buddy who is a Ford guy.......
Re: Battery under hood for race car [Re: AndyF] #2483509
04/16/18 10:59 AM
04/16/18 10:59 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
When I put my battery in the trunk a couple months ago I used a Ford (single small post) type solenoid along with a Painless alternator disconnect on a panel at the battery.
My starter cable runs from the solenoid directly to the starter so it's only hot when cranking. The factory solenoid was left on the fire wall with a hot wire from the disconnect switch in the back feeding power to the post that the + cable was on. Everything except the alternator and starter get power from there. There is a wire from the "start" terminal of the factory solenoid to the single post on the Ford relay in the trunk. My car still has the three post neutral safety switch and wiring, it starts great set up this way.
Re: Battery under hood for race car [Re: AndyF] #2483562
04/16/18 01:04 PM
04/16/18 01:04 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Have you thought about one of those cable shut offs the See Doos use when a person is thrown off? Break away on a trailer comes to mind to also, but maybe not enough amperage. Then there's the fuel pump shut off on vehicles in an accident, this would shut down everything if driver was incapitated, might make a difference till safety personnel could get there. Good to have backup systems.
Re: Battery under hood for race car [Re: AndyF] #2484428
04/17/18 11:29 PM
04/17/18 11:29 PM
Virginia
64HemiSavoy Offline
64HemiSavoy  Offline
Virginia
I've seen stock eliminator cars with a master disconnect on the rear panel. That seems really nuts to me unless there is something else going on with the wiring that I don't know about. If they are running a hot cable all the way to the back just for a disconnect switch then it seems like it is less safe than not having a disconnect.
With a battery up front and no disconnect switch there isn't a lot of hot cable. For my car I'm going to use a Ford type solenoid so the starter cable is only hot while cranking. So the only hot line when the key is off is the BATT feed to the fuse panel under the dash.
Most Stocker's run the battery in the stock under hood location as well as one in the trunk where the disconnect is required.
Re: Battery under hood for race car [Re: AndyF] #2484534
04/18/18 10:52 AM
04/18/18 10:52 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
For the most part all dragster have their batteries up front, many in the nose area of the car. They have to have a cutoff at the rear as the rulebook states, they all usually also have one in the cockpit as well. If you have a door car there are a few in cockpit kits for battery shut off like this one from Lokar that use a Morse cable
https://www.summitracing.com/parts/lok-1330023
Page 2 of 3 1 2 3
