Re: Mallory Unilite timing issue
[Re: sgcuda]
#2488599
04/27/18 10:08 AM
04/27/18 10:08 AM
Posts: 24 NC
BaldwinCarbs
NC
The delay is in the electronics themselves such as an msd box or the orange Mopar box Different brands have different delay. Example, pertronix has about a 2 degree delay @ 5,000 rpm Msd has a 4 degree delay @ 5,000 rpm so you can curve the distributor to counter act the delay. Orange Mopar box, about 7 degrees GM HEI about 2 degrees with a factory module, 7 degrees with these aftermarket ones
Engines produce more torque and hp through the rpm range with a correct curve in them anyways due to piston speed vs combustion chamber design, so we curve the distributor to accommodate the delay also.
[Re: BaldwinCarbs]
#2488605
04/27/18 10:37 AM
04/27/18 10:37 AM
Posts: 8,040 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Thats the piont i was trying to make in an earlier post about how much power is lost thru out the curve if your timing is locked out. Didnt get a good answer on that at the time. But it is easier to just lock it out and forget about it. I was just curious to how much could possibly be left on the table thru the rpm band with a pump gas 511 without a curve built in. How do you figure best curve?
[Re: mopar dave]
#2488617
04/27/18 11:06 AM
04/27/18 11:06 AM
Posts: 24 NC
BaldwinCarbs
NC
Thats the piont i was trying to make in an earlier post about how much power is lost thru out the curve if your timing is locked out. Didnt get a good answer on that at the time. But it is easier to just lock it out and forget about it. I was just curious to how much could possibly be left on the table thru the rpm band with a pump gas 511 with a curve built in. How do you figure best curve? What's your setup?
[Re: mopar dave]
#2488675
04/27/18 01:01 PM
04/27/18 01:01 PM
Posts: 24 NC
BaldwinCarbs
NC
511 with 4.375 bore, 11.25: static comp, mw victors with 330cc port flow 356@.650, solid flat tappet 270/276@50-.644/.615-110 installed 106, 1100 dominator, 2" header, 3400# car with 5000 stall. Run a factory distributor with 2 of the big factory springs that have the big loop in the end. Keep in mind you have to have matching springs with about a .051 wire diameter and a distributor machine. You'll be at 24 degrees initial 26@ 2,000 28@ 3,000 30@ 4,000 32@ 5,000 34@ 6,000
[Re: BaldwinCarbs]
#2488686
04/27/18 01:37 PM
04/27/18 01:37 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
The delay is in the electronics themselves ... So glad you are posting about this. I felt like I was the only one here. And although I'm sure that's not quite true, it does seem like a secret. A stock class racer first told me about how the car always slower when they took out that heavy secondary spring from the DC distributor. I didn't learn the real reason for most of the delay until much later. This is the reason for the solid line and the dashed line in the Direct Connection graph in post #11 here: https://www.forabodiesonly.com/mopar/thr...post-1972040585In theory the timing could increase (depending on the spring perch setting) but on a slow ECU, its flat, which is still a hell of a lot better than losing timing. They set up the heavy spring and weights to counteract the delay in electronic switching (sometimes called slew rate). Every electronic operation takes time. This secondary portion of the advance can't be done with all advance mechanism. That's with the MSD, my suggestion for Dave was to set it up to delay the 'all in' to a higher rpm. That way the slew will have less effect through the top of your power curve. https://www.tapatalk.com/groups/racingfu...-less-t765.htmlMore links on slew in Innova 3568 Timing Light, now slew rate
[Re: Mattax]
#2488718
04/27/18 04:31 PM
04/27/18 04:31 PM
Posts: 24 NC
BaldwinCarbs
NC
The delay is in the electronics themselves ... So glad you are posting about this. I felt like I was the only one here. And although I'm sure that's not quite true, it does seem like a secret. A stock class racer first told me about how the car always slower when they took out that heavy secondary spring from the DC distributor. I didn't learn the real reason for most of the delay until much later. This is the reason for the solid line and the dashed line in the Direct Connection graph in post #11 here: https://www.forabodiesonly.com/mopar/thr...post-1972040585In theory the timing could increase (depending on the spring perch setting) but on a slow ECU, its flat, which is still a hell of a lot better than losing timing. They set up the heavy spring and weights to counteract the delay in electronic switching (sometimes called slew rate). Every electronic operation takes time. This secondary portion of the advance can't be done with all advance mechanism. That's with the MSD, my suggestion for Dave was to set it up to delay the 'all in' to a higher rpm. That way the slew will have less effect through the top of your power curve. https://www.tapatalk.com/groups/racingfu...-less-t765.htmlMore links on slew in Innova 3568 Timing Light, now slew rate Yes, that's half of it. It's not really a secret, just to many people read to much of the internet and drink the koolaid! It's all marketing. The other half of it is the get the correct timing at a given rpm. A 906 Mopar head will not make it's most power at 4,000 with timing set at 38 A 15 degree Brodix head wants like 22 degrees at 4,000 rpm and 28 degrees at 7,000 if that tells you anything With a locked out distributor you have a backwards curve when you add in the slew rate, so the motor is off at all rpms A 602 GM crate motor makes max power at 34 degrees. So when these guys lock their distributors out and run them on the dyno they have to set the timing to 39 degrees to get max power. Well 39 - 5 degrees of slew rate = 34 But this destroys power below the max power rpm
[Re: sgcuda]
#2488728
04/27/18 05:21 PM
04/27/18 05:21 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
LOL, you forgot few variables to add to the timing curve. At peak volumetric efficiency (just past peak torque) needs the least amount of timing. As volumetric efficiency is decreased more timing is needed. At piston acceleration speed goes up (low gear) more timing is needed.
FYI I would love to locate a old distributor machine
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#2488729
04/27/18 05:23 PM
04/27/18 05:23 PM
Posts: 24 NC
BaldwinCarbs
NC
Joe
That's pretty much what I've been explaining in a nutshell lol Just in simple common internet terms lol I'm afraid of talking over people's heads and them losing interest because they can't understand the terminology
[Re: BaldwinCarbs]
#2488770
04/27/18 07:03 PM
04/27/18 07:03 PM
Posts: 4,457 Washington
madscientist
Washington
Joe
That's pretty much what I've been explaining in a nutshell lol Just in simple common internet terms lol I'm afraid of talking over people's heads and them losing interest because they can't understand the terminology Then spell it out. What makes you think we are too stupid to understand what you are saying? It might be you don't express yourself well.
[Re: madscientist]
#2488777
04/27/18 07:19 PM
04/27/18 07:19 PM
Posts: 24 NC
BaldwinCarbs
NC
Joe
That's pretty much what I've been explaining in a nutshell lol Just in simple common internet terms lol I'm afraid of talking over people's heads and them losing interest because they can't understand the terminology Then spell it out. What makes you think we are too stupid to understand what you are saying? It might be you don't express yourself well. Just trying to simplify things for everyone The newbies and the veterans
[Re: sgcuda]
#2488794
04/27/18 07:51 PM
04/27/18 07:51 PM
madscientist
Washington
Put it out there and let everyone learn at their own pace.
What you posted came off as incredibly arrogant.
[Re: madscientist]
#2488797
04/27/18 07:58 PM
04/27/18 07:58 PM
Posts: 24 NC
BaldwinCarbs
NC
What you posted came off as incredibly arrogant. Not intended that way at all Amazing how that can happen over a keyboard lol
[Re: sgcuda]
#2488798
04/27/18 07:58 PM
04/27/18 07:58 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Seems like everyone here is barking up the wrong tree. I’ll ask again... is it a capacitive discharge/ multiple spark system?
[Re: TRENDZ]
#2488801
04/27/18 08:07 PM
04/27/18 08:07 PM
Posts: 24 NC
BaldwinCarbs
NC
I take it your question is about what system has a delay?
[Re: BaldwinCarbs]
#2488833
04/27/18 10:01 PM
04/27/18 10:01 PM
TRENDZ
Milwaukee WI
The Seems like everyone here is barking up the wrong tree. I’ll ask again... is it a capacitive discharge/ multiple spark system?
I take it your question is about what system has a delay? No. It’s about the fact that most dial back timing lights will not trigger correctly with any system that has more than one spark per engine cycle. They get especially finicky at the transition from multiple to single. I don’t know how many times I see this brought up. His “problem” went away with the change to a standard timing light. Any other delay that happens prior to the spark discharge is irrelevant if your equipment is lying to you.
[Re: TRENDZ]
#2488834
04/27/18 10:04 PM
04/27/18 10:04 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Seems like everyone here is barking up the wrong tree. I’ll ask again... is it a capacitive discharge/ multiple spark system? If you are asking about the car I have been working on, as the title says, it's a Mallory Unilite. Not a CD or a MSD system, Just a regular HEI using optical sense instead of magnets.
[Re: BaldwinCarbs]
#2488836
04/27/18 10:10 PM
04/27/18 10:10 PM
sgcuda
With a locked out distributor you have a backwards curve when you add in the slew rate, so the motor is off at all rpms Interesting you mentioned Brodix 15 degree heads. I am building a 605 with B1 originals. High compression, drag race only. This will be in a lightweight stick shift car. RPM range will be 4,500 to 7,500. Maybe a little higher. How would you go about setting up a curve for higher rpm, or is it needed at these speeds.
