Re: Dropping a 360 magnum into my 70 b body few question [Re: 79machocharger] #2485615
04/20/18 02:22 PM
04/20/18 02:22 PM
Andrewh Offline
Andrewh  Offline
There is actually a guy selling the factory aftermarket efi kit for magnums.
at 2200, not sure if it is worth it or not, but it comes with everything you need.
I guess it was for the carb crate engines.
durango/dakota forumns. don't have the link handy.
http://www.dakota-durango.com/forum/showthread.php?t=458698
Re: Dropping a 360 magnum into my 70 b body few question [Re: 79machocharger] #2487712
04/25/18 11:17 AM
04/25/18 11:17 AM
ME
79machocharger Offline OP
ME
So I bought the cam snout extension from Hughes so I can run the v belt set up and mechanical fuel pump and correct fan. How hard is it to switch over? Do I need a timing belt cover off of a la style 360 or will a la 318 work as well. I’ have a couple of la 318’s kicking around that I can rob all of the pulleys from and brackets for alt and power steering.
Re: Dropping a 360 magnum into my 70 b body few question [Re: 79machocharger] #2487720
04/25/18 11:51 AM
04/25/18 11:51 AM
Andrewh Offline
Andrewh  Offline
318 will work for the front stuff.
Re: Dropping a 360 magnum into my 70 b body few question [Re: 79machocharger] #2488021
04/25/18 11:49 PM
04/25/18 11:49 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If you wanted to keep the magnum EFI, its hard to beat the Hot Wire harness. At just over $1,000 it is a stand alone harness that requires 4 wire to be connected for use. There are also wires supplied inside the harness for connecting to gauges and other options. www.hotwireauto,com I've used 3 Hot Wire harnesses, one 5.9 Magnum (into 2 different vehicles now) and two 5.7 Hemi and they work well out of the box. Gene
Re: Dropping a 360 magnum into my 70 b body few question [Re: poorboy] #2488226
04/26/18 01:06 PM
04/26/18 01:06 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
This is sooo true. I love my Hotwire Harness. I also love the SCT handheld tuner and custom tunes from a competent tuner. My 5.9 Magnum based 408 spins out nearly 500 hp & 630 ft lbs of torque at the crank. That coupled with a 3800 stall converter, a 200R4 4 speed automatic w lock-up converter, 3.91 gears and Nitto Drag Radials make my 3700 lbs '68 get up and boogie.
