Re: Building a quiet, low restriction exhaust for a big block [Re: SomeCarGuy] #2479724
04/09/18 12:13 AM
04/09/18 12:13 AM
Someplace you aren't
SomeCarGuy Offline OP
I’d like to look at it up on a rack and lay the system out. Might be hard to stack anything other than bullets, so solution might be a y pipe into a single big muffler and split from it.
I want my fair share
Re: Building a quiet, low restriction exhaust for a big block [Re: SomeCarGuy] #2479755
04/09/18 01:08 AM
04/09/18 01:08 AM
Anybody try a Flowmaster 50 or 70 series on a big block? I got to thinking about 20 years ago I put a system of theirs on a 94 f150 5.0 and it was quiet. Believe it was a force II and it had a 70 series. Pretty hard to compare a single pipe on a 302 to this deal. That and I sold that truck 15 years ago so I can’t remember exactly how it sounded.
Re: Building a quiet, low restriction exhaust for a big block [Re: SomeCarGuy] #2479824
04/09/18 07:54 AM
04/09/18 07:54 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I've got FlowMaster 50s on 2 cars.
My '62 NY stationwagon, with a stock 413ci engine and 2-1/4" dual exhaust, is very quiet.
But its engine burns some oil and it has deposited the soot mostly in the (some 15 year old) mufflers which toned them down very nicely.
Thinking I could copy the sound into my '65 300 convertible with a 400ci with 2.5" dual exhaust and an 'advanced' cam, and it turned out to be fairly loud.
It has the newest of the bought Flowmasters. Has a nice rumble while driving and idling, but is very loud when cold. Actually a bit unsuitable for the car.
My '60 NY with 496ci engine has Dynomax mufflers but I had to add bullet style resonators at the rear to tone them down a bit. But they are still very noticable.
Re: Building a quiet, low restriction exhaust for a big block [Re: SomeCarGuy] #2481111
04/11/18 02:41 PM
04/11/18 02:41 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Where are you at? I've got a pair of Flow Master 70 series mufflers that have never been installed in the rafters of my garage. They're huge. 2.5" inlet/outlet that are both off center.
Re: Building a quiet, low restriction exhaust for a big block [Re: SomeCarGuy] #2481435
04/12/18 01:57 AM
04/12/18 01:57 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
How about a y-pipe into a single 3" super turbo round long welded muffler with a 3" off the shelf v-10 tailpipe? Quiet, cheap and works with a bigger engine than yours.
Re: Building a quiet, low restriction exhaust for a big block [Re: 4406bbl] #2481445
04/12/18 02:22 AM
04/12/18 02:22 AM
dogdays Offline
dogdays  Offline
Dynomax Super Turbos 17748 or 17749 depending on what fits better. They are 2.5" and flow well. Use an X or H pipe and use some more mufflers as resonators.
That's where a long glasspack is helpful.
If you do have to go to single tailpipe it has to be 3". By the time the exhaust has gotten to the back axle it has cooled and contracted some. Huge isn't so necessary back there.
R.
Re: Building a quiet, low restriction exhaust for a big block [Re: SomeCarGuy] #2481447
04/12/18 02:29 AM
04/12/18 02:29 AM
I’m in cincy. I don’t have the truck to see how much room I have under there. It’s getting rubber parts replaced at a shop and a general going over.
Have considered I might have to do a y pipe and maybe split at the muffler. Suppose I could run a faux tip to get the look, seems a hokey thing to do.
Re: Building a quiet, low restriction exhaust for a big block [Re: SomeCarGuy] #2482818
04/15/18 12:12 AM
04/15/18 12:12 AM
Highland, MI.
Sunroofcuda Online content
Sunroofcuda  Online Content
Highland, MI.
Just do it!!!
Re: Building a quiet, low restriction exhaust for a big block [Re: topside] #2483079
04/15/18 02:13 PM
04/15/18 02:13 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Super Turbo's on everything I have/had in the last 20 + yrs,only drawback is my 62 Savoy wagon,complete Max Wedge system all 3" and it is louder than I like but still the quietest 3" performance muffler out there so I live with it.
