Page 3 of 3 1 2 3
Re: Low 10 second B body engine/trans big block combos. [Re: BigHemiVegas] #2481027
04/11/18 12:23 PM
04/11/18 12:23 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If its in the budget, I'd be in the 572 cube camp...... with some mildly reworked 440-1's and an easy-on-parts type roller cam...... 4500 carb, 4800 converter.
Re: Low 10 second B body engine/trans big block combos. [Re: BigHemiVegas] #2481170
04/11/18 04:48 PM
04/11/18 04:48 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
^^^^^^Agree^^^^^^
If I’d have just put the $ I’ve already spent into an aftermarket block, I’d be in far better shape then I am now.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Page 3 of 3 1 2 3
