Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: Wedgeman] #2480647
04/10/18 06:48 PM
04/10/18 06:48 PM
No, absolutely not tsk twocents
A lot of the none Hi Po race machined shops preach what there machine shop instructors taught them in their schooling, if they had any formal training shruggy work
Your golden as far as I'm concerend up
BTW, what parts, rods and crankshaft, did you end up with?
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2480742
04/10/18 09:33 PM
04/10/18 09:33 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
ok if you say .065'' is still ok I will have the machine shop do the work.....
I will use 6.700 chevy rods 1968 440 crank.....440 source +14cc pistons for 12.5cr....
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2480749
04/10/18 09:39 PM
04/10/18 09:39 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i looked at the same deal, haven't talked to a machine shop yet but i have a 440 crank that's already been machined for a lowdeck. it's gonna need a little clean up on the journals (very light surface rust spots) so was thinking to 2.20 rod pin and 3.90 stroke.
but, i'm not sure for a mostly street motor, idling in traffic and the sorts, that i would feel comfortable with that rod side clearance...
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2480752
04/10/18 09:46 PM
04/10/18 09:46 PM
W
Wedgeman Offline
Wedgeman  Offline
W
Scares me too.....but if Cab says so..........I guess it will center itself while running
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2480761
04/10/18 09:58 PM
04/10/18 09:58 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I don't understand why everyone gets so hung up on side clearance. Too little is a concern. I doubt within reason there is such a thing as too much.
I think the oil coming out of the outside of the 2 rods under pressure hits the radius of the journal and tries to push the rods together while the oil on the inside tries to push them apart effectively holding them in a stable position. Assuming everything that is supposed to be round is round and not tapered, there really isn't much reason for them to move at all much less bang into each other.
Kevin
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: Wedgeman] #2480790
04/10/18 10:37 PM
04/10/18 10:37 PM
Did you have your crankshaft grinder offset grind the crank to increase the stroke or just reduce the rod journal size only?
The reason I'm asking is if it is offset ground most shops end up with a standard radius on the inside of the offset centering the rods towards the middle of the rod journal scope
Mopar has used a reverse radius as long as I know of on the rod journals that does not have a step up or a corner for the rod bearing journals to ride up against like all the other OEM makers use scope shruggy
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2480812
04/10/18 11:09 PM
04/10/18 11:09 PM
W
Wedgeman Offline
Wedgeman  Offline
W
Yes I was about to have it offset grind, just found out the old crank is finally just junk !!.....next crank please !
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: Wedgeman] #2480902
04/11/18 02:12 AM
04/11/18 02:12 AM
Ohio Crankshaft CO (800-333-7113) 4.25 stroke up devil
Them or Tom Molnar at 616-940-4640 scope
If your stuck with a 3.91 stroke then I would call 440 Source to see if they have one in stock or not shruggy
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2480907
04/11/18 02:37 AM
04/11/18 02:37 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
For a street car, lower RPM engine, the 4.25" stroker kit with the shorter rod ratio is fine. It will produce alot of low end torque. On a 496" street engine you don't need to mess with the high compression pistons. The 20cc dished pistons should be good for around 10:1 compression with an 80cc head.
I have used the 440 source kits, and they are decent, but have everything inspected and checked if you don't have the tools to do it yourself.
Same with the source heads. Really any of the aftermarket heads need to be disasembled and cleaned as a minimum. I was surprised at how dirty the aftermarket heads are, and that is pretty much true for any of the brands.
The cam you mentioned is really too small for a 496" engine.
The 10230704LK would be OK in the engine 234/242 @ 0.050", 0.513"/0.533" lift. The Voodoo cams use a 3-bolt timing gear, so make sure to order the correct timing chain set for the cam you use.
