Re: Exhaust Interference and Drone Problems
[Re: MuuMuu101]
#2423405
12/25/17 01:57 AM
12/25/17 01:57 AM
Posts: 277 Southwest, Mi.
74Cuda
Southwest, Mi.
I had Full length TTI headers with Dynomax Ultra Flows and full length 2-1/2" tail pipes on my 440 Cuda, and I did not have any drone at all. maybe tail pipes will help.
[Re: earlymopar]
#2423743
12/25/17 10:10 PM
12/25/17 10:10 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
A little off topic but I'm curious how close your headers actually are to your steering box and whether you have any issues with power steering fluid temps.
- EM Well, it's not touching anymore so it probably got cooler.
[Re: 74Cuda]
#2423747
12/25/17 10:12 PM
12/25/17 10:12 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I had Full length TTI headers with Dynomax Ultra Flows and full length 2-1/2" tail pipes on my 440 Cuda, and I did not have any drone at all. maybe tail pipes will help. Our exhaust systems are fairly different as I have shorty (unequal length) headers, a shorter wheelbase car, and different length exhaust tubing with a different engine. I don't think it can be fairly comparable car-to-car.
[Re: MuuMuu101]
#2423954
12/26/17 05:05 PM
12/26/17 05:05 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I just called the exhaust shop that had great reviews on Yelp. It was a one-man shop, but basically he told me that my car is going to drone and there isn't much he can do about it. He said I'd need a muffler that has both packing material and chambers to break up the exhaust while quieting it. He said he's worked on a couple of Dodge Darts and there's no room in front of the mufflers for him to put anything, as I suspected with my 2" between the centerline of the tube and the floor pan. I asked him if there was anything we could do on the tailpipe end like adding a glasspack, chambered muffler, or resonator and he said that odds are all it will do is quiet the car down.
I asked him about the turndowns too and his response was, "Resonance is resonance." So, I'm not sure if I should get another opinion or take all of the knowedge I've gathered from this thread and try something.
I think my next step may be to grab all of my blankets, like mentioned before, shoving them in the trunk, and seeing if maybe that will help as he hasn't had any experience with sound deadening.
[Re: 360view]
#2424033
12/26/17 07:09 PM
12/26/17 07:09 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
The blankets in the trunk is a worthwhile experiment. So is silicone caulking cracks that might vibrate, or filling voids made of flimsy sheet metal.
Another worthwhile experiment is to use Vice-Grips to clamp different sized sockets inside the exhaust pipes at the outlet. This slightly increases the back-pressure and changes the speed of sound in the exhaust gas.
You already mentioned you can hear a difference in the drone was the engine coolant temp went up. That is also a speed of sound in hotter gas effect.
The pictures you have posted seem to show you have room to add closed end T- stubs. These are typically 26 to 18 inches long. Think of these as “blind alleys” the sound wave charges down, hits its head on the closed end, and dies. Start long and trim off length until the sound cancellation is greatest at your cruise RPM. The stub tubes can be bent, even coiled. They can also be the next smaller diameter pipe with just a small decrease in effectiveness.
You could also extend the length of your exhaust pipe past the critical 70 inch length somehow., like have the driver’s side exhaust exit on the passenger side, and vice versa. I just stuffed a blanket, a comforter, a pillow, a large sleeping bag and two foldable mattresses in the trunk and it didn't do much of anything. Granted, there was still a void between the battery and the quarter panel and a little over the rear end but it was 90% filled. I just didn't want to mess up the sheets or anything. I tried to film myself driving the car to capture the drone and ironically, my phone cannot pick up the drone frequency. So, everything sounds fine on the video when it is obviously annoying in real life. I can call the exhaust guy to see if he's heard of or would be interested in a Helmoltz-style resonator, but it didn't seem like he had any idea of what it was or he probably would have brought it up. Is that 70" past the muffler? Rear End? Does it have to be a straight line of tubing?
[Re: MuuMuu101]
#2424035
12/26/17 07:19 PM
12/26/17 07:19 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Tailpipes from the muffler exit out to the open end that measure 55 to 70 inches length on V8s tend to have an annoying drone somewhere at an RPM and throttle opening typical of highway cruise.
The stub pipe does not have to straight. Think of all the curves in headers. The science phenomenon that causes drone is the same one that gives added engine power with headers.
[Re: MuuMuu101]
#2424748
12/28/17 02:30 AM
12/28/17 02:30 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I had Full length TTI headers with Dynomax Ultra Flows and full length 2-1/2" tail pipes on my 440 Cuda, and I did not have any drone at all. maybe tail pipes will help. Our exhaust systems are fairly different as I have shorty (unequal length) headers, a shorter wheelbase car, and different length exhaust tubing with a different engine. I don't think it can be fairly comparable car-to-car. The Dart has a longer wheelbase than any Cuda. Yours is 111" and the 67-69 Barracuda/Cuda is 108". The E body Barracuda/Cuda is also 108".
[Re: Kern Dog]
#2424752
12/28/17 02:58 AM
12/28/17 02:58 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
The Dart has a longer wheelbase than any Cuda. Yours is 111" and the 67-69 Barracuda/Cuda is 108". The E body Barracuda/Cuda is also 108". Fix... "Different wheelbase*"
[Re: MuuMuu101]
#2424785
12/28/17 07:20 AM
12/28/17 07:20 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
So Sunroofcuda's offer to build you a set of resonators that are 3.5" body was not sufficient? He gave sound advice, and your YELP dude muffler shop is an idiot because the factory did install resonators to get rid of the drone!
You keep asking questions for answers you are seeming to ignore. Just cut the friggin tail pipes off, move the mufflers forward, install the resonators and extend the tail pipes past the bumper.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
