Page 15 of 33 1 2 13 14 15 16 17 32 33
Re: IT"S HOME!!!!!! 1972 340 4spd Cuda [Re: Tom_440] #247941
09/08/11 07:04 AM
09/08/11 07:04 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Thanks Tom, I had an upholstry shop glue it on and I instructed them how to trim it so I could do the rest.
For the headliner no one ever told me there were 2 styles used that year, I got the wrong one because I did not know.... need a headliner?
Re: IT"S HOME!!!!!! 1972 340 4spd Cuda [Re: UCUDANT] #247942
09/08/11 07:54 PM
09/08/11 07:54 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
TIP: having a difficult time trying to install your "mouse trap" style spring loaded rear license plate holder? I used vice grips to carefully clamp one side....just the lower half and let the upper section rest down on the pliers like a stop, holding the assembly open....yeah I know but it worked and the car went unscratched
Re: IT"S HOME!!!!!! 1972 340 4spd Cuda [Re: UCUDANT] #247943
09/09/11 08:10 PM
09/09/11 08:10 PM
ama tx
jdr2483 Offline
jdr2483  Offline
ama tx
Nice looking car. What part of New Mexico do you live in? If you get it finished and would like to show it off you can bring it over to Amarillo Texas for the 3rd annual Chrysler's in the Canyon.
Re: IT"S HOME!!!!!! 1972 340 4spd Cuda [Re: jdr2483] #247944
09/10/11 10:06 AM
09/10/11 10:06 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Thanks for the kind words. I'm in Albuquerque NM. Unfortunately my car won't be done in time for your show. Just been too busy to focus on the car and I still haven't sent out my rear bumper for chrome, it has to go to Texas. I need to find an anodizer. And there's always a little snag...wrong headliner etc. Since you all are only a few hr's maybe next year
Re: IT"S HOME!!!!!! 1972 340 4spd Cuda [Re: UCUDANT] #247945
09/10/11 10:45 PM
09/10/11 10:45 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Thanks for the link! It's coming along quite nicely!
2 Demons...no, not my kids!
Re: IT"S HOME!!!!!! 1972 340 4spd Cuda [Re: 4speeds4me] #247946
09/11/11 09:12 PM
09/11/11 09:12 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Thanks.
Here's a sail panel you can see it's not the same material. I am told the type headliner I had was called yorkshire.
Re: IT"S HOME!!!!!! 1972 340 4spd Cuda [Re: UCUDANT] #247947
09/11/11 09:16 PM
09/11/11 09:16 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Is this vinyl it sort of has the feel of old stiff shoe leather or cardboard
Re: IT"S HOME!!!!!! 1972 340 4spd Cuda [Re: UCUDANT] #247948
09/11/11 09:34 PM
09/11/11 09:34 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
close up of material, the grain is only visible in the areas that were not exposed to light
Re: IT"S HOME!!!!!! 1972 340 4spd Cuda [Re: UCUDANT] #247949
09/11/11 09:57 PM
09/11/11 09:57 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
A pic Dante sent of the yorkshire type repop material he has.... I have a sample of this on the way from both Dante and Burdar. Burdar also sent the SMS material. Thanks to both Dante and Burdar for their help
{EDIT} this is the underside the flip side is a more accurate match to my original material
Re: IT"S HOME!!!!!! 1972 340 4spd Cuda [Re: UCUDANT] #247950
09/11/11 11:24 PM
09/11/11 11:24 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
I need to recheck my old sail panels too. Never noticed the grain pattern before now. Thanks
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Parts 1972 340 4spd Cuda [Re: 19cuda73] #247951
09/12/11 09:11 PM
09/12/11 09:11 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
My 72 Cuda had what appeared to be two factory holes for the `Cuda tail panel emblem they align neatly between the centers of the outer most portions of the letter C and the A. The Cuda logo I had was an original of some kind that was drilled to align with these holes. the car was built in late 71 at Hamtramck
I- is the OEM tailpanel emblem with the holes
II- A stick on Dales Cuda shop reproduction Nice part but I still longed for the pin style
III- And finally an Ebay Cuda dual pin/post style reproduction, item is just slightly shorter in length. The pin holes are off, at least for my car. The outer edge is rough and and the thickness even varies. Both ebay emblems are also softer/bendable as if what ever it is made from is a much softer alloy lead or aluminum? Put it this way Scott Smith would throw em out
Parts 1972 340 4spd Cuda [Re: UCUDANT] #247952
09/12/11 09:25 PM
09/12/11 09:25 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
The "by Plymouth" emblem it was paired with in the auction appears correct in size and appearance is very close, however this is made in one solid piece, where the original was 2 parts and they are supposed to have a chrome border and letters this does not
in this shot you can compare the correct style shape and contours of the Dales #II emblem to the ebay part #III
my original by Plymouth emblem
Parts 1972 340 4spd Cuda [Re: UCUDANT] #247953
09/12/11 09:38 PM
09/12/11 09:38 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Another profile shot Thanks to Dales Cuda shop for an accurate part #II. I have had the best luck when purchasing parts from moparts members
Headliner Material 1972 340 4spd Cuda [Re: UCUDANT] #247954
09/12/11 11:05 PM
09/12/11 11:05 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Here's a comparison of the headliner material.
I is the factory material from my car
II is the SMS material from member Burdar ..thanks Dennis
III is Dante's Parts Material provided through Dennis
Re: IT"S HOME!!!!!! 1972 340 4spd Cuda [Re: UCUDANT] #247955
09/13/11 06:01 PM
09/13/11 06:01 PM
STL
cdstl Offline
cdstl  Offline
STL
Are you going to put the headliner material on your sail panel? I haven't gotten a close look at mine but they just look like some kind of vinyl. I'll be waiting to see how you attach it.
Looks good,
Chuck
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: IT"S HOME!!!!!! 1972 340 4spd Cuda [Re: cdstl] #247956
09/14/11 12:09 PM
09/14/11 12:09 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
No, I plan to replicate a stock appearance
Re: IT"S HOME!!!!!! 1972 340 4spd Cuda [Re: UCUDANT] #247957
09/15/11 05:29 PM
09/15/11 05:29 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
HI,
I've been following your thread and just wanted to say your doing an awesome job! Keep up the good work and thanks for posting the pics of the progress and the repro parts. I like the detail distinctions you point out of the parts.
Ray
Re: IT"S HOME!!!!!! 1972 340 4spd Cuda [Re: rayztoy] #247958
09/15/11 11:47 PM
09/15/11 11:47 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Thanks, the AMD bumper arrived today overall a nice looking part. Here are the details. I stacked it against a 73 core I had.... NOTE a 72 bumper has an 18" bumper bracket bolt spacing and a 73 has 13-1/4"
The licence plate area has a bit more "texture" then the stock 73 in the same area.
KEEP IN MIND THIS IS AN OEM 73 BUMPER SO ANY NOTED DIFFERENCES MAY ONLY BE MODEL YEAR CHANGES
Re: IT"S HOME!!!!!! 1972 340 4spd Cuda [Re: UCUDANT] #247959
09/15/11 11:57 PM
09/15/11 11:57 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
The bumper jack slots appear to be at a slight angle but due to the spacing difference and the bumper being V shaped it could be an optical illusion....
Of note is the absence of chrome at the lower hole , also the difference in contour of the lower edge of the bumper, possibly a 72/73 model year difference and maybe not OEM Vs Repro difference can anyone confirm this. A friend does have a 72 in his rafters
Anyone who is following this thread notice the box the bumpers are on?
Re: IT"S HOME!!!!!! 1972 340 4spd Cuda [Re: UCUDANT] #247960
09/16/11 12:01 AM
09/16/11 12:01 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
the OEM 73 has a fish hook jagged point in the underside edge at each end. The 72 Repro does not
