Re: B-body 4-spd. Reverse [Re: Dave Hall] #2479628
04/08/18 09:40 PM
04/08/18 09:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Originally Posted By Dave Hall
Thanks! We'll get to it in a bit. Dealing with interior items right now as it's stupid to bleed brakes and push the clutch with no seat.
...who needs seats, they're overated, ...lol!
Re: B-body 4-spd. Reverse [Re: Dave Hall] #2479954
04/09/18 01:23 PM
04/09/18 01:23 PM
Cotati, CA
Dave Hall Offline OP
Cotati, CA
Ok, work and sleep have to happen so we will update soon...
Re: B-body 4-spd. Reverse [Re: John_Kunkel] #2479965
04/09/18 01:51 PM
04/09/18 01:51 PM
New York
rarefish Offline
rarefish  Offline
New York
Originally Posted By John_Kunkel
There is a special lever alignment tool for Mopar Hurst shifters with only two alignment holes.
As to the stiff Reverse, there is a tang on the internal Reverse lever that interacts with the interlock to prevent Reverse from engaging when in a forward gear, if the tang is to close to the interlock and rubs, the lever will be stiff. Loosening the cover bolts and repositioning the cover will usually make the lever move easier.
I have been looking for one of these tools. Where do you buy one?
The factory Hurst shifter on my 69 Dart also does not have the hole in the reverse rod.
Re: B-body 4-spd. Reverse [Re: Dave Hall] #2479977
04/09/18 02:15 PM
04/09/18 02:15 PM
Cotati, CA
Cotati, CA
I wouldn't worry about it as I found the reverse lever to be pretty independent and was able to adjust it in the car just like you would adjust an auto trans. cable. GREAT NEWS! The side cover was the problem! It was able to swim up nearly an 1/8 inch and everything is free and shifting normally! boogie Thank you so much guys! This forum and it's members are just the shyznit! up up up The owner called me "one diligent mother@#$er!" Haha! He's off to the exhaust shop to get a small rattle over the rear end dealt with and fine tune the clutch adjustment. One happy dude that didn't have his vacation plans ruined because of you guys! biggrin See him in Van Nuys this weekend. I was planning on going and had a room and everything but racing called and I'm off to Dallas for a double div. 4 event tomorrow morning.
Re: B-body 4-spd. Reverse [Re: Dave Hall] #2479981
04/09/18 02:21 PM
04/09/18 02:21 PM
Cotati, CA
Cotati, CA
We went from this
To THIS!!!
Re: B-body 4-spd. Reverse [Re: rarefish] #2480029
04/09/18 03:26 PM
04/09/18 03:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's Miller C-3951, they show up on E-bay occasionally...overpriced as usual.
Re: B-body 4-spd. Reverse [Re: Dave Hall] #2480415
04/10/18 11:57 AM
04/10/18 11:57 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If that side cover moved an 1/8th inch then you have a problem - missing shoulder bolts. With the shoulder bolts in there is virtually no movement.
Re: B-body 4-spd. Reverse [Re: Stanton] #2484192
04/17/18 01:11 PM
04/17/18 01:11 PM
Cotati, CA
Cotati, CA
I didn't move the cover. The owner did and relayed that info to me. The shoulder bolts are present. Car is back from Van Nuys and a few bugs were discovered and being dealt with. Typical of any "new" build. The car took 3rd place in the stock B-body class and would have been 2nd but was dinged for the color change. The Wine Country Mopar Club brought 6 cars and took home 8 trophy's including 2 best of show. Owner had a fantastic time. Thanks again for everyone's input! up
Re: B-body 4-spd. Reverse [Re: Dave Hall] #2485565
04/20/18 12:48 PM
04/20/18 12:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Good thing you did that , hopefull first , if you pulled the detenet without taking the cap and spring and ball out FIRST and instead pulled it out and an assembly you'd be fishing around for the ball as it rills off into the bottom of the trans case ... DAMHIK
Re: B-body 4-spd. Reverse [Re: John_Kunkel] #2485567
04/20/18 12:49 PM
04/20/18 12:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
After seeing your picture John I made my own a decade or so ago.
