Re: Summit Codes
[Re: Kevin Kowalski]
#2480032
04/09/18 03:28 PM
04/09/18 03:28 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Sure is nice to see the 10% codes available again. Heck a guy that I provided a code or two several years ago on Yellowbullet sent me a pm with a couple of codes in it.
Re: Summit Codes
[Re: MoParFish]
#2480696
04/10/18 08:12 PM
04/10/18 08:12 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
Still looking for a Code, The one I got was not valid.
The only Carbs I care about are under the hood!
Re: Summit Codes
[Re: fuseable]
#2480729
04/10/18 09:18 PM
04/10/18 09:18 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
Could use one myself, should one come up. TIA.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Summit Codes
[Re: Azzkikrcuda]
#2480764
04/10/18 10:03 PM
04/10/18 10:03 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Still looking for a Code, The one I got was not valid. I'm waiting on PM's to see if the other 2 codes worked, it sucks that yours didn't work. I've given out a million of these things and never had anyone say they didn't work. I'm trying to see if any of my friends have an extra code for you.
Re: Summit Codes
[Re: ProSport]
#2480771
04/10/18 10:12 PM
04/10/18 10:12 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Just remember you have to enter it exactly right including the date
Ex: 04/16/2018
Not 4/16/18
Re: Summit Codes
[Re: ProSport]
#2480776
04/10/18 10:18 PM
04/10/18 10:18 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
No problem. That’s the only issue I’ve ever seen unless someone posts the code on the forum instead of a pm and someone gets to it first.
Re: Summit Codes
[Re: Silver70]
#2480813
04/10/18 11:10 PM
04/10/18 11:10 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If it was me I would call and have them check it for you. Sometimes it pays to talk to a counter person
Re: Summit Codes
[Re: pittsburghracer]
#2480824
04/10/18 11:34 PM
04/10/18 11:34 PM
ProSport
Akron, Ohio
If it was me I would call and have them check it for you. Sometimes it pays to talk to a counter person I agree. Tell them it's from the Cleveland piston power show and nobody has used it. They might get it figured out or just let you use it.
