Page 2 of 3 1 2 3
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2479192
04/08/18 01:19 AM
04/08/18 01:19 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By OhioMopar
Originally Posted By Thumperdart
Been running the same 22" Summit radiator forever and w/an elec. water pump and HHR fan, it cools my junk pretty well being I live in the HOT High Desert........... beer
I would run cooler with efi over a carburetor, right? gringrin
I guess it's possible..........Carbs cool the intake so nicely though....... beer
Re: 22" aluminum radiator for 600+ horsepower. [Re: fourgearsavoy] #2479207
04/08/18 01:45 AM
04/08/18 01:45 AM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
Are you running hot on the highway or idling around town? Just saying maybe it's not the radiator shruggy I tried everything else before I changed my radiator and found a system that works for my mild(maybe 570) combo. My engine gets up to around 200 when I cruise around on 90 degree days but that is really not overheating.
Gus beer
The car isn't on the road yet. I had the stock radiator in front of the Stealth headed 383 that was in it, and idling and 55-60 it never saw much over 185. When I got on 23 heading north and hit 70-75, it was up around 190.
I have a 440 Source pump and housing on the engine going in it. That's all the cooling system I have figured out so far.
I don't want to cut the core support for a 26". I haven't decide on mechanical or electric fans, although I'm leaning towards a clutch or flex fan.
I run the 440 Source steel pulleys and a 5 blade viscous MP fan with no shroud. If I put a shroud on it I could probably get my cruising around town temp down below 200. My highway temp used to be high over 200 until I put the 1 to 1 pulleys on it.
Gus beer
I was thinking about Source pulleys.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 22" aluminum radiator for 600+ horsepower. [Re: Thumperdart] #2479208
04/08/18 01:46 AM
04/08/18 01:46 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Lol. I'll be calling you in a few weeks to get the specifics worked out on a carb build.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 22" aluminum radiator for 600+ horsepower. [Re: lewtot184] #2479231
04/08/18 03:48 AM
04/08/18 03:48 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By lewtot184
I don't understand radiators and horsepower ratings. why would a radiator have a horsepower rating?
When you modify an engine to make more horsepower, you also increase the heat load on the cooling system.
that's the basic assumption the marketers would spout. I don't buy it. how much time is spent at 600hp vs 60hp? it's all b.s. if more time was spent at 60hp vs 600hp would you buy a radiator 1/10 the size? of course not. vendors will say or do anything to sell something. there are too many other factors in cooling a water cooled engine than peak horsepower.
So, according to you, the factory wasted money installing a 26" radiator in anything...a 22" 2-row should be all any motor needs.
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2479276
04/08/18 10:37 AM
04/08/18 10:37 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
https://www.ebay.com/itm/THE-BEST-Mopar-BIG-BLOCK-22-Wide-ECP-Aluminum-Radiator-REAL-COOLING-POWER/263230865287?hash=item3d49c83f87:g:w7sAAOSw4CFY4qsz&vxp=mtr
I used there 26" 2 row in an A body with a shroud with my 511 filled just about to the top and temps were 185-195 street driving last August. ECP radiators are very good.
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2479439
04/08/18 02:48 PM
04/08/18 02:48 PM
central il.
second 70 Offline
second 70  Offline
central il.
I run a three core 22" champion on my hemi which is close to 600hp and it works fine. I use a fixed fan with a shroud.
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2479447
04/08/18 02:57 PM
04/08/18 02:57 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
$200 Afco aluminum Rad and a 16 inch Spal $135 pusher fan keeps my heap cool.I might have a little more than 600 HP whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 22" aluminum radiator for 600+ horsepower. [Re: mopar dave] #2479814
04/09/18 07:19 AM
04/09/18 07:19 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I've been looking at ECP radiators. I think someone on here said the fitment was all wrong. I know CSK loves his ECP. I have also looked at Northern Radiator and KKS Motorsports. I've heard a couple good things about both. Seems that lots of people have reviews on the 26", 22" seems a little harder to come by.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 22" aluminum radiator for 600+ horsepower. [Re: hemi-itis] #2479815
04/09/18 07:20 AM
04/09/18 07:20 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
You might, indeed. How big is your Afco?
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2479837
04/09/18 09:10 AM
04/09/18 09:10 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I reckon my 414 LA motor is making pretty close to 600, I run a 2 core Race radiator designed as a bolt in replacement for a 240-260Z. It's maybe 22", I have dual fans set to come on at 190 and in all but the hottest days the fans only click on coming down the return road after a pass, sometimes they don't come on at all.
but I run a full time oil cooler from a Freightliner truck and a 9 quart system, I think that helps keep from overtaxing the coolant system pretty well. I'm a big fan of oil coolers
WIZE
In Car:
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2480020
04/09/18 03:22 PM
04/09/18 03:22 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Check your local roundy round shops, that's where mine came from. The factory replacement hoses even work.
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2480140
04/09/18 07:24 PM
04/09/18 07:24 PM
Canada north shore lake Ontari...
ross Offline
ross  Offline
Take a look at Wizard Cooling's web site. I have not got one yet but this is the 22 inch rad I have decided on.
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2480222
04/09/18 10:40 PM
04/09/18 10:40 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 22" aluminum radiator for 600+ horsepower. [Re: ross] #2481373
04/12/18 12:20 AM
04/12/18 12:20 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Those are pretty nice radiators. Another one to add to the list.
I think getting options has made it harder to decide...
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 22" aluminum radiator for 600+ horsepower. [Re: ross] #2481379
04/12/18 12:31 AM
04/12/18 12:31 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
The more I look at the Wizard radiators, the more I think that is the route I will go.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2481380
04/12/18 12:32 AM
04/12/18 12:32 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I've seen those Wizard radiators at the Nats before and they are very well made and he also has a good warranty for fit and performance.
Gus beer
64 Plymouth Savoy
Dana 60
Re: 22" aluminum radiator for 600+ horsepower. [Re: fourgearsavoy] #2481382
04/12/18 12:36 AM
04/12/18 12:36 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Gus beer
That's looking like the direction I'm going to go. They even make an OEM style shroud to go with it. I didn't have one before, so that will help.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2481443
04/12/18 02:18 AM
04/12/18 02:18 AM
I took a look at that web site, is his prices higher or lower than others similar companies? confused
Re: 22" aluminum radiator for 600+ horsepower. [Re: Cab_Burge] #2481448
04/12/18 02:34 AM
04/12/18 02:34 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Higher than Champion or ECP, lower than others. Be Cool and one other is close to $800. So right in the middle.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 22" aluminum radiator for 600+ horsepower. [Re: OhioMopar] #2481449
04/12/18 02:41 AM
04/12/18 02:41 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
When I was looking for a rad recently, read something about 2 vs 3 row... the 2 row have larger openings and actually flow better than the small opening 3 rows. I'm no expert on it, but I would think a bigger core would be better than thinking 3 row over 2 and such.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Page 2 of 3 1 2 3
