Re: Building a quiet, low restriction exhaust for a big block
[Re: SomeCarGuy]
#2479724
04/09/18 12:13 AM
04/09/18 12:13 AM
Posts: 10,201 Someplace you aren't
SomeCarGuy
I’d like to look at it up on a rack and lay the system out. Might be hard to stack anything other than bullets, so solution might be a y pipe into a single big muffler and split from it.
I want my fair share
[Re: SomeCarGuy]
#2479755
04/09/18 01:08 AM
04/09/18 01:08 AM
SomeCarGuy
Anybody try a Flowmaster 50 or 70 series on a big block? I got to thinking about 20 years ago I put a system of theirs on a 94 f150 5.0 and it was quiet. Believe it was a force II and it had a 70 series. Pretty hard to compare a single pipe on a 302 to this deal. That and I sold that truck 15 years ago so I can’t remember exactly how it sounded.
[Re: SomeCarGuy]
#2481111
04/11/18 02:41 PM
04/11/18 02:41 PM
Posts: 4,405 Michigan
MarkZ
Worthy
Worthy
Where are you at? I've got a pair of Flow Master 70 series mufflers that have never been installed in the rafters of my garage. They're huge. 2.5" inlet/outlet that are both off center.
[Re: SomeCarGuy]
#2481447
04/12/18 02:29 AM
04/12/18 02:29 AM
SomeCarGuy
I’m in cincy. I don’t have the truck to see how much room I have under there. It’s getting rubber parts replaced at a shop and a general going over.
Have considered I might have to do a y pipe and maybe split at the muffler. Suppose I could run a faux tip to get the look, seems a hokey thing to do.
