10 Point Cage -- -Do`s and Don`ts #2476922
04/03/18 06:26 PM
04/03/18 06:26 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Have an appointment to have a 10 point cage put in my `Cuda.
DOM 1-3/4" tube
I want swing-out bars on both sides since it will probably see limited street use in the future.
It is being bent on location,NOT a kit. Bars will go between windsheild and dash as tight as possible to the pillar.
I think the rear struts should go to the shock cross member{coil-overs}.
1st experience letting ANYONE touch my car in 37 years. current rollbar I put in in 1986.
Opinions/Advise???
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 10 Point Cage -- -Do`s and Don`ts [Re: 6bblFLASH] #2476927
04/03/18 06:40 PM
04/03/18 06:40 PM
IL
Dart451 Offline
Dart451  Offline
IL
Thought cage could be 1 5/8" tubing
Re: 10 Point Cage -- -Do`s and Don`ts [Re: 6bblFLASH] #2476930
04/03/18 06:45 PM
04/03/18 06:45 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Why 1 3/4"?
Roll cage right?
I would go 1 5/8"
Another thing to think about is going to Chromoly, the cost between DOM and Chromoly is negligible. Yes you have to TIG Chromoly so that might play into it.
To make the bars as tight as can be will be pretty difficult. Without cutting the car it is dam hard to weld the joints on the roof line completely.
Re: 10 Point Cage -- -Do`s and Don`ts [Re: Dart451] #2476931
04/03/18 06:47 PM
04/03/18 06:47 PM
N.E. Ohio
N.E. Ohio
You might be right.
Haven`t discussed with him yet. I`ve seen kits both ways.
1-3/4' was an assumption,probably a wrong one.
Chromemoly is probably not an option.but I will ask him.
1-5/8' would be nicer.
Re: 10 Point Cage -- -Do`s and Don`ts [Re: 6bblFLASH] #2476935
04/03/18 06:52 PM
04/03/18 06:52 PM
IL
Dart451 Offline
Dart451  Offline
IL
Weight difference between tubing for reference
1 5/8 x .083 is 1.367 pounds per foot
1 5/8 x .120 is 1.929 pounds per foot
1 5/8 x .134 is 2.134 pounds per foot
1 3/4 x .120 is 2.089 pounds per foot
1 3/4 x .134 is 2.313 pounds per foot
Not a big difference between 1 5/8 and 1 3/4 .120
Re: 10 Point Cage -- -Do`s and Don`ts [Re: 6bblFLASH] #2476939
04/03/18 06:59 PM
04/03/18 06:59 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Bring an NHRA rulebook printout with you.
I'm with you on the cage being tight to the pillars; much more professional and easy to see around.
On my Duster, the forward bars are in the fender wheelhouses so they're not in the engine compartment; they tie to the shock tower reinforcements.
Re: 10 Point Cage -- -Do`s and Don`ts [Re: topside] #2476955
04/03/18 07:20 PM
04/03/18 07:20 PM
Washington
madscientist Offline
Washington
This^^^^^^^^^ make sure you have a copy of the rule book with you, and then verify EVERYTHING before you pay for it.
That includes sonic testing the tubing and verifying the bars are in the correct location.
Re: 10 Point Cage -- -Do`s and Don`ts [Re: 6bblFLASH] #2476958
04/03/18 07:27 PM
04/03/18 07:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW when I did my E body Cuda years and years ago we did the a pillar bars tight and through the dash. We also ran the rear bars up against the roof to allow for clearance to the rear seat as well. Since mine was more a street car than racecar, although it ran 9's with the blower motor in it.
Re: 10 Point Cage -- -Do`s and Don`ts [Re: 6bblFLASH] #2477004
04/03/18 08:20 PM
04/03/18 08:20 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
There is very little cost difference between DOM and Chrome Moly. CM must be tig welded though. Running the cage through the dash is nice. Makes getting in and out easier. those bars are also tied to the cowl at the windshield base. It also hard to make the dash fit cleanly around the tubes. Who will be doing that? Mine has bars going to the floor and shock mount cross member. The main hoop diagonals tie into the ladder bar mounts.
Doug
Re: 10 Point Cage -- -Do`s and Don`ts [Re: dvw] #2477020
04/03/18 08:42 PM
04/03/18 08:42 PM
N.E. Ohio
N.E. Ohio
My car has an aluminum dash for now.
Eventually I would like something more stock looking, probably fiberglass.
Re: 10 Point Cage -- -Do`s and Don`ts [Re: Biginchmopar] #2477045
04/03/18 09:26 PM
04/03/18 09:26 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Originally Posted By Biginchmopar
Why 1 3/4"?
Roll cage right?
I would go 1 5/8"
There are construction methods that can be used to get the bars up and out tight. Taking the windshield out can help with getting the A pillar and eyebrow bar or halo in. Don't forget frame ties if they need to be included or up graded. Tight fits and clean detailing takes time. Time is money. If you have to take a rule book along and tell the guy how to do it, are you sure you picked the right guy? He should be telling you.
Re: 10 Point Cage -- -Do`s and Don`ts [Re: 6bblFLASH] #2477050
04/03/18 09:43 PM
04/03/18 09:43 PM
Motor City
6PKRTSE Online content
6PKRTSE  Online Content
Motor City
Mine is c.m. and goes through the top of the dash. Notched dash back around the A pillar bars. We tacked all of the main structure in the car. Then spilt it where the rear portion of the A pillar bars ties into the main hoop. Welded everything up 100% outside of the car except at the split. Placed back in car and welded those two spots.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 10 Point Cage -- -Do`s and Don`ts [Re: 6bblFLASH] #2477069
04/03/18 10:16 PM
04/03/18 10:16 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I used CM years back when it was required to have one.My only regrets are not going through the dash or installing a diagonal bar overhead for a parachute release handle.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 10 Point Cage -- -Do`s and Don`ts [Re: 6bblFLASH] #2477217
04/04/18 02:25 AM
04/04/18 02:25 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Dennis nice to see you are working on the Cuda again. I dropped my Cuda off for a redo last month. I am going with CM. Like others said price difference was minimal.
I will be checking the status when I get home next week.
Ok
Re: 10 Point Cage -- -Do`s and Don`ts [Re: 6bblFLASH] #2477280
04/04/18 10:19 AM
04/04/18 10:19 AM
New York
polyspheric Offline
polyspheric  Offline
New York
1-3/4" has 27% more bending resistance than 1-5/8", weighs 8% more.
There are 3 reasons why a cage:
1. pass tech
2. safety
3. chassis response
The same plans are not equally effective in all 3.
Boffin Emeritus
Re: 10 Point Cage -- -Do`s and Don`ts [Re: CMcAllister] #2477428
04/04/18 03:41 PM
04/04/18 03:41 PM
Carson City, Nevada
Carson City, Nevada
Why 1 3/4"?
Roll cage right?
I would go 1 5/8"
I know all about it:
6.0 Cert
Re: 10 Point Cage -- -Do`s and Don`ts [Re: Biginchmopar] #2477429
04/04/18 03:44 PM
04/04/18 03:44 PM
Carson City, Nevada
Carson City, Nevada
We cut the roof off
Re: 10 Point Cage -- -Do`s and Don`ts [Re: 6bblFLASH] #2477442
04/04/18 04:23 PM
04/04/18 04:23 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You can tack it and the current the sill plate outriggers. Drop it down, weld the top and then lift it back up. Good fit is key.
Doug
Re: 10 Point Cage -- -Do`s and Don`ts [Re: polyspheric] #2477474
04/04/18 05:40 PM
04/04/18 05:40 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
1. pass tech
2. safety
3. chassis response
Serious questions: Do you even own a racecar? Have you ever raced a car?
'63 Dodge 330
11.19 @ 121 mph
Re: 10 Point Cage -- -Do`s and Don`ts [Re: 6bblFLASH] #2477844
04/05/18 12:34 PM
04/05/18 12:34 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I missed the ceremony in which you were given supreme authority to approve credentials.
Apparently those comments are both strange and frightening to you.
You're right, I'm 12, and ride a bicycle, which means I must be wrong.
Exactly what part of my remark is error?
Boffin Emeritus
