Re: Who’s 383 stroker kit is the most bang for the buck???
[Re: Wedgeman]
#2480647
04/10/18 06:48 PM
04/10/18 06:48 PM
Posts: 43,332 Bend,OR USA
Cab_Burge
No, absolutely not A lot of the none Hi Po race machined shops preach what there machine shop instructors taught them in their schooling, if they had any formal training Your golden as far as I'm concerend BTW, what parts, rods and crankshaft, did you end up with?
[Re: Wedgeman]
#2480790
04/10/18 10:37 PM
04/10/18 10:37 PM
Cab_Burge
Did you have your crankshaft grinder offset grind the crank to increase the stroke or just reduce the rod journal size only? The reason I'm asking is if it is offset ground most shops end up with a standard radius on the inside of the offset centering the rods towards the middle of the rod journal Mopar has used a reverse radius as long as I know of on the rod journals that does not have a step up or a corner for the rod bearing journals to ride up against like all the other OEM makers use
[Re: Wedgeman]
#2480902
04/11/18 02:12 AM
04/11/18 02:12 AM
Cab_Burge
Ohio Crankshaft CO (800-333-7113) 4.25 stroke Them or Tom Molnar at 616-940-4640 If your stuck with a 3.91 stroke then I would call 440 Source to see if they have one in stock or not
[Re: mopar_leaner]
#2480907
04/11/18 02:37 AM
04/11/18 02:37 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
For a street car, lower RPM engine, the 4.25" stroker kit with the shorter rod ratio is fine. It will produce alot of low end torque. On a 496" street engine you don't need to mess with the high compression pistons. The 20cc dished pistons should be good for around 10:1 compression with an 80cc head. I have used the 440 source kits, and they are decent, but have everything inspected and checked if you don't have the tools to do it yourself. Same with the source heads. Really any of the aftermarket heads need to be disasembled and cleaned as a minimum. I was surprised at how dirty the aftermarket heads are, and that is pretty much true for any of the brands.
The cam you mentioned is really too small for a 496" engine. The 10230704LK would be OK in the engine 234/242 @ 0.050", 0.513"/0.533" lift. The Voodoo cams use a 3-bolt timing gear, so make sure to order the correct timing chain set for the cam you use.
