Re: 76 Volare, yes a volare.
[Re: modelmakerinc]
#2516657
07/02/18 10:27 PM
07/02/18 10:27 PM
Posts: 2,438 west palm beach, florida
modelmakerinc
Back when I first began fixing this thing, I cut the cowl open to access the Swiss Cheese beneath. In doing so, The factory plastic cover doesn't fit so I had made an aluminum vent cover. Since paint is basically done went ahead and installed it.
It has panel nails to hold in down.
[Re: modelmakerinc]
#2537745
08/17/18 04:42 PM
08/17/18 04:42 PM
modelmakerinc
Finished wetsanding and buffing to where I was originally intended to leave it, got the brakes partially bled, and the exhaust buttoned up so I was able to drive it out of the shop and into the daylight under its own power, I need to raise the front a bit still and add the correct wheels and tires.
Now I can work on finishing the bumpers and interior pieces with the car outside. The side pipes have a cool sound but not as bad as some say with only hearing one bank at a time, I installed a h pipe so I think that helped.
getting closer to a driver and fully expect to have it at the Garlits show this November.
[Re: modelmakerinc]
#2543153
08/29/18 05:01 PM
08/29/18 05:01 PM
Superfreak
Superfreak
Mighty fine job you have done there Henry.
