Original AAR Exhaust Tips #2475278
04/01/18 12:32 PM
04/01/18 12:32 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Hey guys, I hoping theres an expert on these things to confirm my suspicion. I have a set of megaphone exhaust tips that I have good reason to believe are NOS, but without a PN on them its tough to say for sure. I did find a set pictured on Ebay where the tips had a tape ID tag on them that supports why I wouldn't find a stamped number.
Heres a few pics with details, perhaps one of you can confirm.
Re: Original AAR Exhaust Tips [Re: AAR#2] #2475282
04/01/18 12:37 PM
04/01/18 12:37 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Both have the internal deformed pipe
Re: Original AAR Exhaust Tips [Re: AAR#2] #2475287
04/01/18 12:39 PM
04/01/18 12:39 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Each is deformed intentionally leading up to the chrome tip
Re: Original AAR Exhaust Tips [Re: AAR#2] #2475288
04/01/18 12:39 PM
04/01/18 12:39 PM
MD
floyd Offline
floyd  Offline
MD
I’m pretty sure originals and NOS have a weep hole on the underside in the pipe near where the chrome tip starts. I haven’t seen repros with those.
Re: Original AAR Exhaust Tips [Re: AAR#2] #2475292
04/01/18 12:43 PM
04/01/18 12:43 PM
MD
floyd Offline
floyd  Offline
MD
I’d guess those are repros. In addition to the lack of weep holes, I’ve never seen an NOS pair with really nice chrome or great black paint. I can post some pics of an NOS set later tonight.
Re: Original AAR Exhaust Tips [Re: AAR#2] #2475293
04/01/18 12:43 PM
04/01/18 12:43 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
and each carry a raised dimple at the muffler connection.
Re: Original AAR Exhaust Tips [Re: AAR#2] #2475295
04/01/18 12:43 PM
04/01/18 12:43 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The NOS tail pipes have a small locating tab on the inlet tube.
I have not seen that on any reproductions yet.
Re: Original AAR Exhaust Tips [Re: AAR#2] #2475304
04/01/18 12:52 PM
04/01/18 12:52 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I have an NOS one here and I have a pair of restored originals installed on my T/A.
(the quality of the chrome on these is poor enough that I doubt anyone would want to install an NOS pair on their car without having them rechromed first).
My NOS has the Chrysler part number tag approximately 4" from the chromed end "megaphone". There is a 3/16" diameter drain hole on the bottom of the pipe in the middle of the area around 6" from the end that installs in the muffler. The flat on the pipe leading into where it's welded to the tip doesn't have a distinct tooling mark like that shown in your picture.
And finally something I noticed on originals that I'm not sure if the repros have, is a small nipple or nub 1-3/4" from the end that installs in the muffler which is an indicator mark to how far the pipe inserts into the muffler exit pipe.
It's been a while since I looked closely at a repro, so I don't know if they have these details the originals have.
Re: Original AAR Exhaust Tips [Re: floyd] #2475306
04/01/18 12:53 PM
04/01/18 12:53 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Thanks for the help, and you would ask about the bottom, I don't recall anything particular about them on the bottom other than what appears like two small weld spots.
And who said the chrome or paint is nice, LOL They do look pretty good but I got these with the car purchase 12 years ago from a guy who purchased the car as a project in 1982. He started collecting parts for the 'one day' project. He lived in TX for a bit and moved to AZ shortly after purchase, so I suspect these have been stored in a great environment for this period.
Re: Original AAR Exhaust Tips [Re: Alaskan_TA] #2475317
04/01/18 01:01 PM
04/01/18 01:01 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Barry, are you thinking of the notch on the muffler?
Re: Original AAR Exhaust Tips [Re: AAR#2] #2475321
04/01/18 01:04 PM
04/01/18 01:04 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The locating tabs on the pipes fit in the notches on the mufflers.
Re: Original AAR Exhaust Tips [Re: Alaskan_TA] #2475329
04/01/18 01:09 PM
04/01/18 01:09 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
So am I to understand that both connections to the muffler carried the cutout tab, meaning that both the head pipe and exhaust tip would have the added mating slug welded to it?
If thats the case, this is an easy visual to say these are not originals.
Any pics of this? or perhaps one of the others will post up pics shortly
Re: Original AAR Exhaust Tips [Re: AAR#2] #2475337
04/01/18 01:18 PM
04/01/18 01:18 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Heres a set of mufflers listed as original that recently posted on Ebay, note the notch appears only on one side.
I also included the claimed original tips, that coupled with another factor had making me think these could be legit.
Screen Shot 2018-04-01 at 8.11.29 AM.pngScreen Shot 2018-04-01 at 8.12.03 AM.png
Re: Original AAR Exhaust Tips [Re: AAR#2] #2475342
04/01/18 01:23 PM
04/01/18 01:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
"positioning spuds" mentioned in the installation instructions at http://www.hamtramck-historical.com/imag....%2080%20p2.jpg
Re: Original AAR Exhaust Tips [Re: AAR#2] #2475343
04/01/18 01:25 PM
04/01/18 01:25 PM
Crook County, ILL
Crook County, ILL
There is a tab on original head pipes that inserts into the slot.
The nub or nipple prevents the tip from being installed too deep into the muffler, and gives a guide as to how far the tip inserts into the muffler. There is no slot for it, you install the tip until the nub contacts the muffler exit pipe.
Re: Original AAR Exhaust Tips [Re: Mastershake340] #2475349
04/01/18 01:32 PM
04/01/18 01:32 PM
Crook County, ILL
Crook County, ILL
Just noticed something else while looking at my NOS tip. There are actually 2 positioning spuds (as an engineer I need to use the correct term, thanks Barry for clarifying that!). And the positioning spuds are on a horizontal plane on the pipe (9 o clock and 3 o'clock positions when the pipe is installed)
Re: Original AAR Exhaust Tips [Re: Mastershake340] #2475396
04/01/18 02:56 PM
04/01/18 02:56 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Any chance of getting a pic of either set you have?
Re: Original AAR Exhaust Tips [Re: AAR#2] #2475399
04/01/18 03:02 PM
04/01/18 03:02 PM
Crook County, ILL
Crook County, ILL
I'll take some pictures. I'm usually on my iPad these days but will fire up the ol laptop later today, download the pix and post.
Re: Original AAR Exhaust Tips [Re: Mastershake340] #2475411
04/01/18 03:27 PM
04/01/18 03:27 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Sorry I dropped off for a bit, its Easter and I got called to Cheese Cake duty, pretty mean Amaretto recipe.
So I just went and pulled the tips again and to my surprise there are two spuds on each. Since its hard to capture both I have my fingers placed over them to show orientation. I'd call the clocking about 11 and 5 on these
While I had them out I saw no sign of any "Drain Hole", I'd sure like to see your clocking and drain hole pics.
And thanks for all the help guys
Re: Original AAR Exhaust Tips [Re: AAR#2] #2475422
04/01/18 03:47 PM
04/01/18 03:47 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
On a side note I had these as well . . . just thought interesting.
