904 VB Q's
#2474594
03/30/18 10:27 PM
03/30/18 10:27 PM
RapidRobert
I need to unblock the 2-3 shift valve. Is it inside the cover with 3 screws or the one on the other side with 5 screws? what should I set the band clearances to (circle track '67 SB 904 shifting normally up thru the gears/spending most time in 3rd). there's an in lb spec then back off a # of turns but I had a problem with that so if you have a clearance amt that might be better (5/16 1/4?) but I could use both for both bands. which filter should I get, the "regular" pale yellow ones or another type? thank you for your time. EDIT its the one with the 3 screws/end valve (gotta love Google).
Re: 904 VB Q's
[Re: 4406bbl]
#2474720
03/31/18 02:29 AM
03/31/18 02:29 AM
RapidRobert
I checked the archives & they said 1/4" (front) & 5/16" (kickdown). there was a thread awhile back on the best filter choice but I failed to write it down.
Re: 904 VB Q's
[Re: 4406bbl]
#2474932
03/31/18 04:21 PM
03/31/18 04:21 PM
RapidRobert
its just a stock 904 but I wanted to adj the bands/replace the filter while I am in there unblocking 3rd gear. Are you thinking a bit more than 1/4 on the front one might benefit me?
Re: 904 VB Q's
[Re: RapidRobert]
#2474982
03/31/18 06:39 PM
03/31/18 06:39 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I checked the archives & they said 1/4" (front) & 5/16" (kickdown). there was a thread awhile back on the best filter choice but I failed to write it down. The front IS the kickdown.
Re: 904 VB Q's
[Re: RapidRobert]
#2475041
03/31/18 08:06 PM
03/31/18 08:06 PM
John_Kunkel
Rio Linda, CA
Factory style Dacron is the best for filtering.
Re: 904 VB Q's
[Re: RapidRobert]
#2476506
04/02/18 10:42 PM
04/02/18 10:42 PM
RapidRobert
On the rear band it says to get 5/16 between the lever and the top of the spring retainer & I'm confused on that: is this the gap between the underside of the (horizontle) lever down to the rim of the spring retainer? & I noticed today that there was no big accumulator spring, should I add one?
Re: 904 VB Q's
[Re: 4406bbl]
#2476609
04/03/18 02:01 AM
04/03/18 02:01 AM
RapidRobert
Oh OK, I should be measuring the "gap" like a plug gap or any gap & not overcomplicate it. those specs were in the Moparts archives. I just saw 2 utube vids & one said front- 4 turns out from snug/rear 2 turns and another vid said start from snug then back off till driveshaft will turn barely by hand then loose another 1/2 turn & same on the other band ex the shaft will be turned the other way (I've read that (last) procedure before).
Re: 904 VB Q's
[Re: RapidRobert]
#2476871
04/03/18 04:54 PM
04/03/18 04:54 PM
John_Kunkel
Rio Linda, CA
vid said start from snug then back off till driveshaft will turn barely by hand then loose another 1/2 turn & same on the other band ex the shaft will be turned the other way You do realize that the force required to turn the driveshaft by hand will vary with the difference between a 98-pound women and Arnold Schwarzendonker turning the shaft? Whoever dreamed up that procedure is an idiot. Stick with the "turns out" like the factory did it. 2 turns for front and rear, the exception being the controlled load (large shaft) front servo piston which takes 2 1/2 turns out.
Re: 904 VB Q's
[Re: John_Kunkel]
#2476940
04/03/18 07:00 PM
04/03/18 07:00 PM
RapidRobert
Agreed, this thing is getting out of hand. OK (2) turns out from "snug" on both bands & I'm wondering about too, should I snug em with the oddball socket & 1/4 ratchet or torque the socket to 72 in lbs? & 2nd question, I was over there this AM & I cant for the life of me get the parking pawl to seat the last slight bit (~1/4") into the ext housing so the VB will line up where it needs to be to be mounted. what am I missing there?
Re: 904 VB Q's
[Re: RapidRobert]
#2476964
04/03/18 07:37 PM
04/03/18 07:37 PM
John_Kunkel
Rio Linda, CA
Stick your finger into the Park rod opening in the tail and apply pressure to the sprag as you turn the driveshaft, you'll feel the sprag drop into the notch in the support. Then you'll be able to insert the Park rod. Be sure you're inserting the rod into the sprag and not under it.
Re: 904 VB Q's
[Re: John_Kunkel]
#2476967
04/03/18 07:41 PM
04/03/18 07:41 PM
RapidRobert
John I will do & do you want me to start from "snug" or 72 in lb.
Re: 904 VB Q's
[Re: John_Kunkel]
#2477112
04/03/18 11:19 PM
04/03/18 11:19 PM
RapidRobert
You do realize that the force required to turn the driveshaft by hand will vary with the difference between a 98-pound women and Arnold Schwarzendonker turning the shaft? Whoever dreamed up that procedure is an idiot. I was wondering about that myself as I was lying on my back reaching up to turn the yoke with my left hand which was wet with trans fluid! Before I left I did get the front kickdown band set to 1/4 as I was able to get the 1/4 allen wrench easily up there to set that gap then tighten the locknut on the outside of the case. since it is done I am gonna leave it as is as this is my only progress so far (unless you convince me otherwise). On the rear band I ain't sure how I will be able to set that gap to 5/16 like I originally planned since the lever contacts what it contacts way down inside the raised lip of the retainer so I will do as you directed, I will torque it to 72 then back off (2) turns & call it good. I will note your info on the pawl & hopefully that goes in place. Thanks John
