Page 3 of 3 1 2 3
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2485557
04/20/18 12:38 PM
04/20/18 12:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By mopar_leaner
Anybody used the Mopar performance aluminum dual plane intake pn P4529117
It has an rpm range of idle to 5800?
If you can find one , it's no longer made , that intake is an alum copy of the 70/72 factory 4bbl and should clear air grabber using the stock 383 base.
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2485561
04/20/18 12:41 PM
04/20/18 12:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Also look for an Ebrock DP4B, that is a tad taller than stock but it clears , I run one on the 383 in my 69 bee with airgraabber.
I also have a stock 70/72 Iron intake that's bee acid ported that I got off a board member that got it from a stock class racer.
Page 3 of 3 1 2 3
