Ok guys, MAJOR revelation here!
As you all know, we’ve been trying to reverse engineer the old technique of “Coach Painting” as explained in this web site:
http://www.stephen.hull.btinternet.co.uk/ For decades, guys in Britain have painted cars, double decker buses, Rolls Royces with a brush and alkyd enamels designed for vehicles. The only problem is, the paint they use (Tekaloid) is not available outside of Britain.
So we’ve been stuck trying to tweak a rust paint to behave like an auto paint. Another problem, is the fact that neither Rustoleum or Tremclad have offered us any documented advice or assistance on the feasibility of their paint for autos.
As much as I hated TheSamba.com, there was one post in there that peaked my interest. Someone mentioned using paint from a company called Fine Paints of Europe.
I wrote Fine Paints of Europe to see if their paint was similar to Tekaloid. Here’s the PRESIDENT’S reply:
“Yes indeed our Dutchlac enamel paint is suitable for use on automobiles.
Quite honestly a brushed applied enamel is not going to have the same appearance as a professional “baked” finish applied in a clean room. The paint will however be serviceable and is it suitable for re-painting automobiles from an appearance and durability perspective.
Cars should be painted in a relatively dust free environment – this is normally easily achieved by parking the car in an enclosed garage and soaking the floor 24 hours before the paint is applied in order that dust can settle out. The temperature of the sheet metal on the automobile should be less than 80 degrees F and the paint should be applied in thin, even coats. The ideal applicator would be the Omega Spalter or Lily Varnish as featured in the Specifier’s Manual.
For first class work we would recommend that the automobile be gently abraded with fine emery cloth and washed before painting. Any areas of rust must be primed and then sanded out – primed with Ferrous Metal primer.
Dutchlac brilliant enamel will work fine at either full strength or slightly diluted. Please understand that paints of this caliber will dry overnight but require a full 28 days to “cure” to maximum hardness.
If you are interested in achieving a sprayed on appearance with brush on paint, it is possible to allow the paint to cure for 28 days (the car can be used while you wait) and then polish the car out with pumice and then rottenstone to provide a beautiful buffed out appearance. If you wish to take this final polishing step please contact me by phone directly in order that we can discuss the method directly.
There are innumerable Volkswagens and Volvo driving around New England with paint jobs from Fine Paints Of Europe.
Thank you for your interest.
Cordially,
John Lahey
President
Phone: 802-457-5899
Fax: 802-457-3984
Email:
exec@finepaints.com PS. Our paint is also widely used by craftsmen who restore coaches. It’s a small market but on in which we take great pride"
Here’s their website guys:
http://www.finepaintsofeurope.com/index.htmlNote they DO have local locations for most of us.
Those of you trying to refine Charger’s technique, please continue to do so ( I am, 'cause I've already gone too far with it.) It’s just that here’s an alternative for those who are just starting out.
