Re: Pros and Cons of Engine/Motor plate
[Re: Cab_Burge]
#2473745
03/29/18 10:53 AM
03/29/18 10:53 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
A motorplate is very convenient. It's a great place to mount things like the coil, vacuum pump, breather tank, alternator, etc. Much easier to unbolt than typical motor mounts...makes engine removal and installation much easier. Plus it frees up a bunch of room under the car when you get rid of the standard mounts and brackets on the K frame. MUCH better for header clearance...especially on a hemi. It's probably stronger too now that you've tied it all in to the frame rails...acts as a stiffener b/t the front rails.
[Re: gsmopar]
#2473756
03/29/18 11:17 AM
03/29/18 11:17 AM
Posts: 4,213 New York
polyspheric
New York
Just remember that a plate resists rotation ("roll") very well - it's in shear. But weak w/r/t angularity ("yaw", lateral motion, like moving the tailshaft left-right).
Boffin Emeritus
[Re: gsmopar]
#2473821
03/29/18 01:57 PM
03/29/18 01:57 PM
Posts: 31,106 Oregon
AndyF
What are the pros/cons of using a Plate vs Schumacher Spool Type Mounts in a 2nd Gen Hemi application in a '69 B-Body?
My current parts list: Gerst Suspension TTi 2 1/4 Headers Indy Maxx block and SR Heads
Thanks!!! I assume since you have the Maxx block that you're going to be making some power. Once you get up past 700 or 800 hp the stock type mounts really have a tough time holding the engine in place. You can use the stock mounts and add a torque strap but typically the serious guys just move to a plate. I wouldn't use a plate on a daily driver type of car, but I would use a plate once you start making some serious power.
[Re: AndyF]
#2473846
03/29/18 03:05 PM
03/29/18 03:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use both a motor plate and a mid plate on my Rampage but its a tube chassis car.. the plates add to the rigidity to the chassis.. I also have plates on the race car.. the Rampage is a street rod.. it drives very nice on the road ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: gsmopar]
#2473851
03/29/18 03:28 PM
03/29/18 03:28 PM
Posts: 4,592 Motor City
6PKRTSE
Motor City
Even with or without a mid plate in addition to your front plate. Don't forget to add the engine limiters for front to rear movement also.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: AndyF]
#2473881
03/29/18 04:29 PM
03/29/18 04:29 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
Thanks!!! I assume since you have the Maxx block that you're going to be making some power. Once you get up past 700 or 800 hp the stock type mounts really have a tough time holding the engine in place. You can use the stock mounts and add a torque strap but typically the serious guys just move to a plate. I wouldn't use a plate on a daily driver type of car, but I would use a plate once you start making some serious power. Thanks Andy! Yes, Indy Maxx block a little north of the 800hp mark. I'm going with the AR Engineering plate.
[Re: gsmopar]
#2473885
03/29/18 04:33 PM
03/29/18 04:33 PM
an8sec70cuda
You'll still need some sort of fore/aft limiter. I use a setup similar to this...
[Re: an8sec70cuda]
#2473991
03/29/18 07:42 PM
03/29/18 07:42 PM
gsmopar
Arizona, USA
You'll still need some sort of fore/aft limiter. I use a setup similar to this... Nice!
[Re: an8sec70cuda]
#2474032
03/29/18 09:08 PM
03/29/18 09:08 PM
Posts: 1,472 Martinsville, IN
cdwmotorsports
Martinsville, IN
You'll still need some sort of fore/aft limiter. I use a setup similar to this... Why? I had elephant ears on a BB A-body on the street for more than 15 years and never had that setup.
eBay-cdwmotorsports
[Re: MR_P_BODY]
#2474099
03/29/18 11:02 PM
03/29/18 11:02 PM
Posts: 10,560 Rittman Ohio
fourgearsavoy
Rittman Ohio
It all depends on the application, Stick car needs a fore-aft for sure to keep the clutch linkage in check. I use Andy's plate and a fore-aft limiter with rod ends attached to the K-member back to the side bolt on the blow shield and it keeps my clutch adjustment constant. I had a conversation with Herb McCandless about this and he told me the the block will have less stress if you use a motor plate ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) something about the block being pulled on the skirt near the main centerline. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 62SAVOY]
#2475893
04/02/18 10:23 AM
04/02/18 10:23 AM
an8sec70cuda
I run solid plate on front and a solid tranny mount on mine. Street driven with no issues. I got tired of ripping stock rubbers. Would be worse on tearing them up now with the blower on it. Have you ever hooked it up at the track? Slipping and sliding on the street won't stress much.
[Re: cdwmotorsports]
#2475896
04/02/18 10:27 AM
04/02/18 10:27 AM
an8sec70cuda
You'll still need some sort of fore/aft limiter. I use a setup similar to this... Why? I had elephant ears on a BB A-body on the street for more than 15 years and never had that setup. B/c the plate or ears WILL flex fore/aft. How much depends on your trans mount and the power you're making. I use a poly mount. Stiffer than rubber, but still allows some movement. Also, like I said above...slipping and sliding on the street doesn't stress things nearly as much as actually getting traction at the track.
[Re: gsmopar]
#2476193
04/02/18 04:36 PM
04/02/18 04:36 PM
Posts: 562 Ohio
lockjaw-express
Ohio
Fore/Aft limiters are required!
I use the Jegs Panhard Bar Kit that they sell. BTW, buy the AR engineering motorplate, as the ears will stress the water pump gaskets.
Mark
