Re: 1969 RR with a stroker 383
[Re: mopar_leaner]
#2474475
03/30/18 05:32 PM
03/30/18 05:32 PM
Posts: 59 Florida
Sweet5ltr
If you're running exhaust manifolds, honestly, you probably can't get better than the original .528 MP solid-lifter camshaft (.502" lift after lash). AndyF did some pretty extensive testing, this camshaft was the best he found for exhaust-manifold applications. The VooDoo series wasn't available at that time, the Lunati camshaft above has less than 240* duration; you should be fine with running manifolds.
On the intake, it's tough for the low-decks. I would personally go with a Holley Street Dominator, wouldn't even consider anything else.
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
[Re: mopar_leaner]
#2474740
03/31/18 03:32 AM
03/31/18 03:32 AM
Posts: 43,315 Bend,OR USA
Cab_Burge
Go to United Machine, KB web site and use the compression ratio calculator to find out exactly what true mechanical compression ratio you will get with flat top pistons with valve reliefs, 80..0 CC heads and a .039 or .042 thick head gasket with a 4.40 bore size ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) You may need a 10 to 12 CC reverse dome, half dish piston to keep the compression under 10.5 to 1 or so for todays pump swill
[Re: mopar_leaner]
#2475044
03/31/18 08:12 PM
03/31/18 08:12 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
383 .060 Over 438 Stroker 440 Source Icon Pistons Flat Tops
Bore size 4.310 Stroke 3.75 Rod 6.76 Comp Height 1.320 Below Deck -.025 4cc Valve reliefs
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: mopar_leaner]
#2480336
04/10/18 02:37 AM
04/10/18 02:37 AM
Posts: 797 WA
pro451bee
WA
