Re: New Viper brake kit
[Re: mopardude318]
#2510276
06/19/18 02:59 AM
06/19/18 02:59 AM
Posts: 31,002 Oregon
AndyF
anything available for a mustang 2 spindle? I have no plans of ever making anything for a Mustang II spindle. Lots of other folks make brake kits for Mustang II. You shouldn't have any trouble finding stuff that will fit those spindles.
[Re: AndyF]
#2520499
07/11/18 01:31 PM
07/11/18 01:31 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
Why the FMJ knuckle vs the 73-76 A-body knuckle? It seemed like everything was geared toward those before. For the 11.75 upgrade they even warned against using the FMJ knucles, "Do not succumb to the temptation to use “lookalike” knuckles from later Mopars, such as 1973-up B/R-bodies, F/J/M bodies, etc. These parts, while visually very similar, are taller, altering suspension geometry (camber change, bump steer, etc.), and possibly forcing the ball joints beyond their designed range, a/k/a “over angling”." Just wondering if that was incorrect information or what the deal is as a layperson. Plus I already have a pair of the A body knuckles. This would be for a '68 Charger.
[Re: AndyF]
#2520732
07/11/18 09:05 PM
07/11/18 09:05 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The A vs FMJ spindle issue has been rehashed here repeatedly. It boils down to preference really. The quote you provide was an incorrect, off the cuff comment that had zero facts to back it up. If you want numbers and facts https://www.bigblockdart.com/techpages/spindles.shtml
[Re: AndyF]
#2520740
07/11/18 09:29 PM
07/11/18 09:29 PM
Posts: 200 Colorado
Bob J
Colorado
Thank you for that page, I don't need it now but it might come in handy later down the road.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
[Re: Supercuda]
#2520950
07/12/18 11:01 AM
07/12/18 11:01 AM
challenger70
Berwyn, IL
The A vs FMJ spindle issue has been rehashed here repeatedly. It boils down to preference really. The quote you provide was an incorrect, off the cuff comment that had zero facts to back it up. If you want numbers and facts https://www.bigblockdart.com/techpages/spindles.shtml I am reading it now, thanks! My car will be more protouring than race so I will probably just stick with my A-body Knuckles, but keep an eye out for some FMJ if I happen upon them.
[Re: AndyF]
#2521188
07/12/18 08:33 PM
07/12/18 08:33 PM
Supercuda
About to go away
About to go away
up yours
You are more likely to happen upon FMJ spindles than A body ones.
[Re: AndyF]
#2521223
07/12/18 10:05 PM
07/12/18 10:05 PM
Supercuda
About to go away
About to go away
up yours
No need to repop FMJ spindles, but yes Fatman Fab makes a dropped one.
The FMJ spindles have been in production from 1973 till 1989 in B, F, M, J, R bodies.
The A body spindle is 73, 74, 75, 76.
Probably 15 FMJ spindles for every A spindle made.
[Re: Supercuda]
#2521441
07/13/18 01:24 PM
07/13/18 01:24 PM
AndyF
There are a couple of different "FMJ" knuckles. I use the later style which is lighter weight. Either will work, but the latest ones are 1.5 lbs lighter. I think some engineer at Mopar finally learned how to use finite element analysis in the 80's since the last version of the knuckles shows that they took weight out of areas with no stress.
[Re: AndyF]
#2521839
07/14/18 03:15 PM
07/14/18 03:15 PM
Posts: 19,366 north of coder
moparx
i'll bet i've done, and advised/supervised around 100 or so FMJ spindle conversions to date, and have encountered absolutely NO problems what so ever, including bump issues and "ball joint overextension". i respect e-boogers wisdom and knowledge, and really appreciate him writing up these articles [right now, he is doing a two part rear disc conversion in mopar action, using late model jeep components.] but his concern about the FMJ knuckle, in my opinion, is without merit. as to the fatman lowered knuckle, that is, from the pics i've seen, a pressed in pin to a flat piece of steel, welded to an upper balljoint tapered bung. i have never held one in person, nor do i know what material the plate, spindle pin, or balljoint bung, are made from.
[Re: AndyF]
#2521885
07/14/18 05:15 PM
07/14/18 05:15 PM
Supercuda
About to go away
About to go away
up yours
Already did the rear disc swap myself on an 8 3/4.
Not too difficult.
[Re: moparx]
#2533250
08/08/18 12:58 PM
08/08/18 12:58 PM
Posts: 5,388 Pikes Peak Country
TC@HP2
Pikes Peak Country
i'll bet i've done, and advised/supervised around 100 or so FMJ spindle conversions to date, and have encountered absolutely NO problems what so ever, including bump issues and "ball joint overextension". i respect e-boogers wisdom and knowledge, and really appreciate him writing up these articles [right now, he is doing a two part rear disc conversion in mopar action, using late model jeep components.] but his concern about the FMJ knuckle, in my opinion, is without merit. as to the fatman lowered knuckle, that is, from the pics i've seen, a pressed in pin to a flat piece of steel, welded to an upper balljoint tapered bung. i have never held one in person, nor do i know what material the plate, spindle pin, or balljoint bung, are made from. The Fatman units are a bit scary looking, but they were designed for the street rod, fairgrounds cruising crowd. I did speak to someone once who had these and I asked him to weigh them. IIRC, they are something like 1.5-2# heavier than the A body spindle.
