Re: Street strip toy!
[Re: viperblue72]
#2470663
03/22/18 08:43 PM
03/22/18 08:43 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
I have seen one of those at Woodburn racing in Sportman, I'm told it has a 440 motor in it and runs in the 12.s I believe A friend of mine has a 1966 that he is working on for a street rod, leaning tower of power with a three on the tree originally, he is planning using a 360 with a 904 or 727, what ever he can get and use easily Did Dodge make the pickup version in both 98 and 108 wheelbases?
[Re: moparlulu]
#2470698
03/22/18 09:42 PM
03/22/18 09:42 PM
Posts: 771 Btween a rock and a hard place
moparlulu
Here is the only picture, if it works! of the brakes, you basically get the brackets and a parts list, it's a Scarebird kit. They make kits for the early d series pickups too. The converter would stall 3800 behind a mild 451 I had in the truck. Cab, I've seen that A-100, he has had it over here at Firebird, not a very talkative guy??? I'm hoping the thing will at least run as fast as my old pickup! Or I'll be putting in a roll bar for nothing!!! [img] https://image.ibb.co/erfe0H/image.jpg[img]
[Re: moparlulu]
#2470722
03/22/18 10:55 PM
03/22/18 10:55 PM
Superfreak
Superfreak
We have a few of those in these parts and they definitely look cool hotrodded up.
[Re: moparlulu]
#2470839
03/23/18 08:33 AM
03/23/18 08:33 AM
Posts: 10,019 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A local boneyard owner put a 383 in the back of one in my home town back in the 60s. He skipped the driveshaft, and bolted the front yoke right to the rear end! I didn't see it run much. I suspect the lack of a driveahaft created an issue or two!
[Re: Dave Hall]
#2471229
03/24/18 04:18 AM
03/24/18 04:18 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Those look so cool with fat tires and pizza cutters... I second that!
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: justinp61]
#2679287
07/19/19 11:58 PM
07/19/19 11:58 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
You've made good progress on it in a short time. I'm looking forward to seeing done.
Have a great day Iowan
"obsolete is neat"
[Re: BloFish]
#2679335
07/20/19 09:12 AM
07/20/19 09:12 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I know few guys with a'z,,,,,,you might need some sissy sticks! LMOL!! Fast street/strip is quite a balancing act as you know !
