Re: What went wrong?
[Re: Shatar4]
#2470010
03/21/18 09:41 PM
03/21/18 09:41 PM
Posts: 1,038 Howell, Mi
Shatar4
Howell, Mi
Wondering what you used for push rods and lifter preload?
Do ya got a vid of this dyno session or of the car running, id think it probably dont sound well when running either. I do have a video but have no idea how to post it here https://youtu.be/0TVC1dn6SwI
[Re: Shatar4]
#2470014
03/21/18 09:47 PM
03/21/18 09:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I really think your cam timing is retarted.. check the crank zero mark first.. I wouldnt pull the engine yet.. pull the timing cover and check the cam timing again
[Re: MR_P_BODY]
#2470019
03/21/18 09:50 PM
03/21/18 09:50 PM
Shatar4
Howell, Mi
I really think your cam timing is retarted.. check the crank zero mark first.. I wouldnt pull the engine yet.. pull the timing cover and check the cam timing again Would that make me lose half the hp? I was thinking cam lobe's or something. To lose that much hp, it has to be affecting all the cylinders.
[Re: Shatar4]
#2470025
03/21/18 09:53 PM
03/21/18 09:53 PM
MR_P_BODY
I really think your cam timing is retarted.. check the crank zero mark first.. I wouldnt pull the engine yet.. pull the timing cover and check the cam timing again Would that make me lose half the hp? I was thinking cam lobe's or something. To lose that much hp, it has to be affecting all the cylinders. A retarted cam will act just like that.. I check the cam 3-4 times when I put them in and it'll be slow reving
[Re: MR_P_BODY]
#2470038
03/21/18 10:04 PM
03/21/18 10:04 PM
dartman366
Mt. Vernon, Ohio
I really think your cam timing is retarted.. check the crank zero mark first.. I wouldnt pull the engine yet.. pull the timing cover and check the cam timing again Would that make me lose half the hp? I was thinking cam lobe's or something. To lose that much hp, it has to be affecting all the cylinders. A retarted cam will act just like that.. I check the cam 3-4 times when I put them in and it'll be slow reving i have to agree with Mike, sounds like its laboring untill it get's up so then it liven's up after that.
[Re: MR_P_BODY]
#2470080
03/21/18 10:50 PM
03/21/18 10:50 PM
Shatar4
Howell, Mi
There is a lot of ups and downs in the pulls There was then he changed the primary jets and it cleaned it up. The last sheet is after the jet change. Was at Jakes for 5 hrs trying to figure this out.
[Re: Shatar4]
#2470256
03/22/18 10:16 AM
03/22/18 10:16 AM
Posts: 13,360 Marion, South Carolina [><]
an8sec70cuda
Nothing wrong w/ the parts list IMO. Definitely something stupid holding it back. The lifters could be an issue, but there's no reason a hydraulic shouldn't pull to 6k+ rpm. Might need different lifters if those are bleeding down. A solid roller would be my choice too, but the hydraulic you have should work.
Check things like where the cam is in at, verify the TDC mark on the balancer is where it should be, verify you don't have lobes going flat, etc.
FWIW...my old stock stroke 440, 10:1, basically stock 906 heads w/ the 509/292 purpleshaft (w/ stock stamped rockers and stock pushrods) made 340 hp on the chassis dyno and ran 11.80s at 112 mph at 3700 lbs.
