Re: Hemi block casting dates
[Re: fastmark]
#2918755
05/05/21 08:25 AM
05/05/21 08:25 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Fastmark, no, they did not stamp later blocks like that, the pads were blank aside from possible machining notes and the WT (Water Tested Block) which all Hemi blocks were supposed to receive after being tested.
[Re: curbman68]
#2919375
05/06/21 02:30 PM
05/06/21 02:30 PM
Posts: 43,368 Bend,OR USA
Cab_Burge
That is a Mega block, not a OEM Mopar hemi cast block ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) the cast in M being the key ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I look at that picture a little closer and maybe that is NOT a M ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) I have a Mega Hemi block motor in my shop now in a 1969 R.R. so I will look at it a little closer later, it definitely has the cast in M on the passenger side, I'll have to look at the casting number on that side of the block ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: Cab_Burge]
#2919624
05/07/21 10:07 AM
05/07/21 10:07 AM
Posts: 3,152 tennessee,usa
mattsmopars
tennessee,usa
That is a Mega block, not a OEM Mopar hemi cast block ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) the cast in M being the key ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I look at that picture a little closer and maybe that is NOT a M ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) I have a Mega Hemi block motor in my shop now in a 1969 R.R. so I will look at it a little closer later, it definitely has the cast in M on the passenger side, I'll have to look at the casting number on that side of the block What block are you referring to? Matt
[Re: Cab_Burge]
#2919640
05/07/21 11:10 AM
05/07/21 11:10 AM
Posts: 1,716 central il.
second 70
central il.
That is a Mega block, not a OEM Mopar hemi cast block ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) the cast in M being the key ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I look at that picture a little closer and maybe that is NOT a M ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) I have a Mega Hemi block motor in my shop now in a 1969 R.R. so I will look at it a little closer later, it definitely has the cast in M on the passenger side, I'll have to look at the casting number on that side of the block Cab here are the 2 mega block castings 1 has full water jackets the 1 with Mopar is siamese. Mike
[Re: fastmark]
#2927882
05/28/21 09:28 PM
05/28/21 09:28 PM
Posts: 5,124 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
There were some blocks cast in 1974, would have to dig some old Chrysler Performance Books up to remember if there were any long blocks with 1974 Casting or short blocks. I remember Mancini in around 1978 got a few short block Hemis and had them for sale but I dont remember the casting dates on the blocks. The stamping on the bottom of the pan rail I have never come across those markings on another block that was cast in 72-74.The Markings on that pan rail tell the story of the block,.when it was machined, when it was assembled and what number it was assembled at and what year is might of gone into. Since 1974 and up there were no Hemi Vehicles I know of being built the block would be an over the counter something. Top Fuel, Funny Car did not run this block at this time would of been a Keith Black likely for them.
1971 HEMI E BODY REGISTRY
[Re: hemicar1971]
#3092965
11/09/22 08:41 PM
11/09/22 08:41 PM
Posts: 10,781 North Dakota
6PakBee
North Dakota
There were some blocks cast in 1974, would have to dig some old Chrysler Performance Books up to remember if there were any long blocks with 1974 Casting or short blocks. I remember Mancini in around 1978 got a few short block Hemis and had them for sale but I dont remember the casting dates on the blocks. The stamping on the bottom of the pan rail I have never come across those markings on another block that was cast in 72-74.The Markings on that pan rail tell the story of the block,.when it was machined, when it was assembled and what number it was assembled at and what year is might of gone into. Since 1974 and up there were no Hemi Vehicles I know of being built the block would be an over the counter something. Top Fuel, Funny Car did not run this block at this time would of been a Keith Black likely for them. I have an NOS 1974 casting PN 3690010 with the description in the 1973 catalog as 'Hemi Engine - Blown'.
[Re: AAR4Fun]
#3093406
11/11/22 12:16 PM
11/11/22 12:16 PM
6PakBee
North Dakota
Pics..?
Thought block in my last post was a blower block as well until I recently discovered it's a D5 block. Literally, there is NO information about D5 Blocks outside of what folks have posted. All Hemi blocks at that time were cast here in Indy, but this has a different casting number. As far as I can tell, it is a normal casting with the heavier webs and a relocated exhaust pushrod holes.
Be nice to hear from someone who may know more about the D5 Blocks... Buried in the shop. I'll see if I can get to it, no promises. The only way I had of knowing the PN was that what was on the cardboard box it came it. Box has disappeared over the 30 years I've had the block but I recorded the PN as I recognized even then it was an odd PN.
[Re: 6PakBee]
#3093414
11/11/22 12:33 PM
11/11/22 12:33 PM
Posts: 8,383 fredericksburg,va
cudaman1969
fredericksburg,va
Some guy awhil back posted that he worked at the foundry that made those blocks and there were many pallet full (a lot) sitting outside, mid 70s or so
[Re: 6PakBee]
#3093502
11/11/22 04:20 PM
11/11/22 04:20 PM
Posts: 8 Indy
AAR4Fun
Indy
Did some digging today and found out some additional information. Talked to a gentleman in Illinois who was a close friend of Tom Hoover and worked in the racing industry during that time. Yes, there was such a thing as a D5 block for the D5 Heads. He had not seen a D5 block, but know they existed. He suggested talking to Ray Barton, he may know more about it.
Reached out to Ray and yes, they were a Pro Stock block for the experimental D5 head program and had less water jacket in the Intake pushrod area to allow for the relocated intake pushrod closer to the cylinder, thus the different casting number. He mentioned building a few blown drag boat engines using those blocks in the past and use to come across them from time to time. The block will accept regular Hemi heads without modifications, but was designed for D5 heads.
Now, just have to decide what makes sense for it...
