Re: is an air filter benefical for air flow around the carb? [Re: DGS] #2467648
03/17/18 09:33 AM
03/17/18 09:33 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Now I really want to try a honeycomb (about 1" thick) on top of the carb (would only work without choke horn). This would remove almost all turbulence just above the boosters.
Re: is an air filter benefical for air flow around the carb? [Re: DGS] #2467673
03/17/18 11:11 AM
03/17/18 11:11 AM
Canada
onig Offline
onig  Offline
Canada
I googled carb honeycomb, couldn't find anything. Who can explain with a pic or two?
69 Dart
Re: is an air filter benefical for air flow around the carb? [Re: onig] #2467684
03/17/18 11:54 AM
03/17/18 11:54 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Here is a honeycomb for a MAF where they are used to straighten the air flow to ensure a proper metering. Should work on a carb just as well.
