Fuel pump recommendations for a 500hp '71 440? #2466698
03/15/18 12:08 AM
03/15/18 12:08 AM
Nanaimo, BC
N
NOrrTH Offline OP
NOrrTH  Offline OP
N
Nanaimo, BC
Engine wont fire after sitting a couple/few weeks without dumping gas down the carb. I don't think its the new Edlebrock 800 cfm accelerator pump. Its still running the oem fuel pump and I've done heads, cam, intake, etc. Been told I should think about upgrading it.
Can anyone recommend a good replacement for it?
Thank you.
'71 GTX N96 auto 3:55 '74 Challenger 440+6 4spd 4:10 '71 Duster 340 auto 4:10
Re: Fuel pump recommendations for a 500hp '71 440? [Re: NOrrTH] #2466701
03/15/18 12:15 AM
03/15/18 12:15 AM
California
mickm Offline
mickm  Offline
California
The Carter mechanical race pump is a good pump, although you will want a regulator. They make one that is supposed to b limited to 5-6 psi, but I've seen as high as 10 from two of them. That's what I have on my car now.
The Carter bowls are vented. With today's gas evaporating the way it does, there is nothing you can do about it sitting. If I haven't fired mine in more than 2 weeks I just automatically dump some gas down the carbs and fire it up.
Re: Fuel pump recommendations for a 500hp '71 440? [Re: mickm] #2466705
03/15/18 12:32 AM
03/15/18 12:32 AM
South Carolina
carhunter Offline
carhunter  Offline
South Carolina
I run the carter racing pump also without regulators,no problems now in 5yrs.572 Hemi dual carters.
Re: Fuel pump recommendations for a 500hp '71 440? [Re: NOrrTH] #2466812
03/15/18 10:29 AM
03/15/18 10:29 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
I've used the Carter race pump on a few builds w/ no regulator...no problems.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Fuel pump recommendations for a 500hp '71 440? [Re: NOrrTH] #2467153
03/16/18 12:07 AM
03/16/18 12:07 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Edelbrock makes a good mechanical pump. I can tell you for a fact it won’t solve the dry bowl issue. After three days I still need to pour gas down the carb. Before then it’s golden.
I want my fair share
Re: Fuel pump recommendations for a 500hp '71 440? [Re: an8sec70cuda] #2467251
03/16/18 10:44 AM
03/16/18 10:44 AM
portland, ct
Since1822 Offline
Since1822  Offline
portland, ct
https://www.summitracing.com/parts/crt-m4862/overview/make/plymouth
Is this the pump you guys are talking about ?
Re: Fuel pump recommendations for a 500hp '71 440? [Re: NOrrTH] #2467270
03/16/18 11:46 AM
03/16/18 11:46 AM
SomeCarGuy Offline
SomeCarGuy  Offline
You need to add an electric if you want to stop the problem you are having. You need one that will let fuel go through when offunless you want to ditch the mechanical altogether. Just running an electric for a few seconds will fill the bowls when dry
Re: Fuel pump recommendations for a 500hp '71 440? [Re: NOrrTH] #2467287
03/16/18 12:30 PM
03/16/18 12:30 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I've run the Carter but with a Holley red pump, I'm going with a Quick Fuel electronic pump now.
Have a great day
Iowan
"obsolete is neat"
Re: Fuel pump recommendations for a 500hp '71 440? [Re: Iowan] #2467432
03/16/18 06:04 PM
03/16/18 06:04 PM
California
mickm Offline
mickm  Offline
California
Re: Fuel pump recommendations for a 500hp '71 440? [Re: mickm] #2467541
03/16/18 10:47 PM
03/16/18 10:47 PM
IN
ahy Offline
ahy  Offline
IN
My two carb vehicles run electric pumps... for good start after sitting and to eliminate hot weather vapor lock and heat soak issues. Even the best mechanical pump will not help in these areas. Current specification gas just does not work well with carb and mechanical pump.
I'll suggest the Carter electric for your application.
Re: Fuel pump recommendations for a 500hp '71 440? [Re: ahy] #2467829
03/17/18 07:23 PM
03/17/18 07:23 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Carter Street/Strip pump from Mancini Racing.
'63 Dodge 330
11.19 @ 121 mph
