Re: Suggestions needed for 2nd Gen HEMI intake. [Re: GTSDave] #2466826
03/15/18 11:01 AM
03/15/18 11:01 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Compression is just at 13-1 with victor jr. heads - I will be running C-12 to be safe its in a 64 dodge NSS. its screaming for bigger carbs - I have a solution for that - but that will be down the road a little
Re: Suggestions needed for 2nd Gen HEMI intake. [Re: DoubleD] #2466886
03/15/18 01:32 PM
03/15/18 01:32 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Nice piece. My 528" as pictured above made slightly more than that with only 10.5:1 on 93 pump gas since I still street drive all of my cars. Yep, I knew mine was going to want more for carbs which is why I went with the tunnel ram and two 1050's.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Suggestions needed for 2nd Gen HEMI intake. [Re: GTSDave] #2467095
03/15/18 09:52 PM
03/15/18 09:52 PM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
There are guys going 9.0s-8.80s with Hemis in NSS with the Indy X ram and stock 750 Eddy carbs.
The intake works, esp in the bigger inch engines.
Re: Suggestions needed for 2nd Gen HEMI intake. [Re: rickseeman] #2467238
03/16/18 09:54 AM
03/16/18 09:54 AM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
Originally Posted By rickseeman
Good. Now we need someone (maybe AndyF) to chime in as to which of those 2 would make more power. I have not run the Stage V. I hate say anything good about Indy but I couldn't believe it when we took off a $3,500 Ray Barton intake and put on a Mod Man and only lost 3 hundreths.
Which Barton intake? I'm only asking because I'm running a modman and it works great for what I do but I figured one of his single planes would really wake my combo up. shruggy
Re: Suggestions needed for 2nd Gen HEMI intake. [Re: Uncle Barry] #2468530
03/19/18 12:00 PM
03/19/18 12:00 PM
an8sec70cuda Offline
Had to be a crossram. The only thing the big Barton or Indy single 4500 intakes won't outrun is a good tunnelram.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Suggestions needed for 2nd Gen HEMI intake. [Re: GTSDave] #2469065
03/20/18 12:37 PM
03/20/18 12:37 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
It was one of his Super Stock intakes. I will try and find a pix.
2011 Drag Pak Challenger
Re: Suggestions needed for 2nd Gen HEMI intake. [Re: rickseeman] #2469069
03/20/18 12:43 PM
03/20/18 12:43 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
It was like this but aluminum with an inline top
Re: Suggestions needed for 2nd Gen HEMI intake. [Re: GTSDave] #2469088
03/20/18 01:04 PM
03/20/18 01:04 PM
Richmond, Tx. (Houston)
GTSDave Offline OP
GTSDave  Offline OP
RICKSEEMAN, That Barton intake is a very nice looking intake! I found one of the INDY Cross Rams and a very fair price, and ordered it in this week. It should work well for what I am trying. If not, then I will look at other options.
Thanks for all the advice!
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Suggestions needed for 2nd Gen HEMI intake. [Re: GTSDave] #2469110
03/20/18 01:48 PM
03/20/18 01:48 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
GTSDAVE - you mentioned you had a A/AH short block do you know if the deck height is standard as most A/AH deck heights are milled more than .100 - hence the reason they all run the sheet metal intakes now
Re: Suggestions needed for 2nd Gen HEMI intake. [Re: GTSDave] #2469111
03/20/18 01:48 PM
03/20/18 01:48 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I am kinda late to this thread but if your Indy cross ram does not work out I would check with Barton or Charlie Wescott about possibly an old SS/AH piece.
Re: Suggestions needed for 2nd Gen HEMI intake. [Re: GTSDave] #2469113
03/20/18 01:52 PM
03/20/18 01:52 PM
GTSDave Offline OP
GTSDave  Offline OP
DoubleD, you are correct.
The deck is milled. I can't run the sheet metal intakes in NSS. The plan is to work the intake to fit. My deck height is 10.40.
-Dave
Re: Suggestions needed for 2nd Gen HEMI intake. [Re: GTSDave] #2469115
03/20/18 01:59 PM
03/20/18 01:59 PM
Netherlands
72Challenger Offline
Netherlands
How would this work out, an old Weiand 2x4 dommie carb setup?
Re: Suggestions needed for 2nd Gen HEMI intake. [Re: 72Challenger] #2469122
03/20/18 02:12 PM
03/20/18 02:12 PM
GTSDave Offline OP
GTSDave  Offline OP
Tunnel rams are not allowed in the NSS classes I run in. I have the bottom of one of those manifolds, but not the carb section. Even if I did, I couldn't use it. Wish we could....
Re: Suggestions needed for 2nd Gen HEMI intake. [Re: GTSDave] #2469123
03/20/18 02:12 PM
03/20/18 02:12 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Yeah thats a tough assignment then - I have seen the Indy tunnel Ram cut down and a sheet metal plenum installed for that purpose - I would guess that would be the easiest path for NSS - I actually priced that out with Wilson - they want a brand new never used intake to cut-up and then a big pile of money to weld it all back togethor! - hence the reason I have a stage V for NSS
