Fuel cell foam with in-tank EFI pump question? #2466000
03/13/18 08:38 PM
03/13/18 08:38 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I am putting an in-tank EFI retro-fit pump into my fuel cell that has the foam blocks inside it.
Is it OK for the foam to just wrap around the pump, or do I need to cut the foam for clearance around the pump?
The pump will be between two block of foam, sort of like the fuel sending unit.
Re: Fuel cell foam with in-tank EFI pump question? [Re: 451Mopar] #2466003
03/13/18 08:43 PM
03/13/18 08:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I like to make a hole for the pump to set in
but have the foam for anti slosh
wave
Re: Fuel cell foam with in-tank EFI pump question? [Re: 451Mopar] #2466225
03/14/18 05:37 AM
03/14/18 05:37 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I am thinking of making a hole in the foam to make it easier to remove and install the pump.
Re: Fuel cell foam with in-tank EFI pump question? [Re: 451Mopar] #2466267
03/14/18 10:59 AM
03/14/18 10:59 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Did exactly this - works awesome up
Re: Fuel cell foam with in-tank EFI pump question? [Re: 451Mopar] #2467216
03/16/18 04:55 AM
03/16/18 04:55 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
All done, it all went pretty easy.
I just need to double check the clearance from the pump inlet to the bottom of the fuel cell.
