Re: UCA Offset Bushings - Use them or not?
[Re: MoJoe]
#2467870
03/17/18 09:15 PM
03/17/18 09:15 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
I'm not sure if they made a noticeable difference when I used them... Actual results can vary from car to car. Assembly tolerances when new were lousy and you put 50 years of neglect or abuse, and the results will vary even more. Some cars can get 6* with these, some will struggle to get up to 2*. In either case, it can give a 2-3* of additional adjustment over the standard bushing. For a few bucks more than a standard bushing, why not try them.
[Re: BPBP440]
#2468008
03/18/18 09:33 AM
03/18/18 09:33 AM
Posts: 5,913 ohio
ruderunner
ohio
Can confirm TCs statement. Range of adjustment can vary widely. After aligning a half dozen b bodies mine with offset bushings was the only one that could get over 2* caster without positive camber. The others were all standard bushings. Worst one couldn't get positive caster without positive camber but the owner had the rear end jacked up for tire clearance.
Angry white pureblood male
[Re: BPBP440]
#2468057
03/18/18 12:00 PM
03/18/18 12:00 PM
Posts: 350 central IL
myduster360
central IL
Extra camber is easy to gain by shimming the ball joint, if you cant get enough Caster.
1972 Swinger 3.6L Pentastar Diablo CMR tuner
[Re: MoJoe]
#2468130
03/18/18 03:29 PM
03/18/18 03:29 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
I should clarify my statement by saying that there may have been more adjustment offered by the offset bushings but I didn't notice much difference in the handling of the car. I also did not have the car long enough to weigh in on tire wear either. What are the optimal caster and camber settings for a 69 b body with a stock suspension, rubber bushings with a 15x7 wheel and a 235/70 tire? ~3 deg positive caster ~.25 deg negative camber What where your measured alignment numbers before and after?
[Re: BPBP440]
#2468603
03/19/18 03:10 PM
03/19/18 03:10 PM
TC@HP2
Pikes Peak Country
Shimming which ball joint...upper...lower? How? Putting hardened washers between the lower ball joint and spindle on the mounting bolts increases negative camber.
