Re: turning piston diameter down [Re: rowin4] #2468440
03/19/18 02:07 AM
03/19/18 02:07 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Cut them loose and forget about them. up Not worth the time and money to consider them at this point. up
Re: turning piston diameter down [Re: rowin4] #2468565
03/19/18 01:30 PM
03/19/18 01:30 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
They can set under my bench just as well as his. LOL
Re: turning piston diameter down [Re: LSP] #2468641
03/19/18 04:27 PM
03/19/18 04:27 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By LSP
Originally Posted By cudaman1969
I would say all if not all NASCAR engine builders turn their own pistons.
No, the only team turning any pistons is Hendrick.
Really?
Re: turning piston diameter down [Re: cudaman1969] #2469127
03/20/18 02:18 PM
03/20/18 02:18 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Really?
Last I heard couple years ago.
A place called Combustion Technologies was roughing their billets, then finished in house.
Childress tried to, then gave up.
Most are on Mahle or Pankl these days.
Designing/making pistons not as easy as it sounds, the machining and inspection equipment is spendy.
Re: turning piston diameter down [Re: LSP] #2469159
03/20/18 03:02 PM
03/20/18 03:02 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
U
Really?
Maybe just the tops then
Re: turning piston diameter down [Re: rowin4] #2469443
03/20/18 11:28 PM
03/20/18 11:28 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Yes, some cut pockets & dishes a little deeper, but not so much that it ruins top groove flatness.
