turning piston diameter down
#2465449
03/12/18 10:00 PM
03/12/18 10:00 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
A friend of mine has a set of JE gas ported pistons that are .060 0ver .They have lite scratches on the skirts. He's going to toss them. Could they be turned down to a .030 over size? and if so at what cost.
Re: turning piston diameter down
[Re: rowin4]
#2465491
03/12/18 10:38 PM
03/12/18 10:38 PM
rowin4
I'm sure they would clean up at .055 .I just never heard of it being done or how the piston would beheld to do the turning.
[Re: rowin4]
#2465509
03/12/18 10:55 PM
03/12/18 10:55 PM
Posts: 1,840 South Bend
John Brown
South Bend
Years ago I had a set of .060 over oem pistons turned undersized so they would check legal for a NHRA stocker. It was done somewhere in Detroit, but the engine builder never revealed his source. Whoever did the job cam ground them to the same specs as TRW pistons. Going fast in a NHRA stocker was never cheap.
[Re: rowin4]
#2465628
03/13/18 03:23 AM
03/13/18 03:23 AM
Posts: 43,227 Bend,OR USA
Cab_Burge
I had a set of 9second Phils pistons hard anadised in SO CA to save them, he had a bad set of solid lifters that the tops started failing allowing pieces of them to get embedded into the forged Ross pistons skirts, they where 4.080 340 pistons and he didn't want to go to the next size bigger so we saved them by doing what we had done That company was a aerospace company and they won't do them anymore that company made them exactly the same size as they where new, we could of had another .0010 to .0030 added onto the diameter of the skirts for no extra costs On your deal I wouldn't hesitate a second to look at some of the current coatings out there now to save them Don't take a chance on doing anything not proven, it ain't worth it to take a chance on any Hi Po motor parts
[Re: rowin4]
#2465664
03/13/18 10:20 AM
03/13/18 10:20 AM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
A friend of mine has a set of JE gas ported pistons that are .060 0ver .They have lite scratches on the skirts. He's going to toss them. Could they be turned down to a .030 over size? and if so at what cost. Got a pic of the worst one?
[Re: LSP]
#2465929
03/13/18 06:43 PM
03/13/18 06:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
A friend of mine has a set of JE gas ported pistons that are .060 0ver .They have lite scratches on the skirts. He's going to toss them. Could they be turned down to a .030 over size? and if so at what cost. Got a pic of the worst one? If they are just lightly scuffed I'd use them.. I have used some fairly ruff ones.. just use a stone on them.. you will be surprised.. I have had 1 set coated and they are still working well on a street engine
[Re: rowin4]
#2466172
03/14/18 01:35 AM
03/14/18 01:35 AM
rowin4
I talked to a engine builder and had him look at them, he said he'd run them as is . This of coarse changed my game plan of getting a free set of $800. pistons as the owner of them was there also. Now he's peed as he bough a new set on advice of another builder.
[Re: rowin4]
#2466206
03/14/18 03:02 AM
03/14/18 03:02 AM
MR_P_BODY
I talked to a engine builder and had him look at them, he said he'd run them as is . This of coarse changed my game plan of getting a free set of $800. pistons as the owner of them was there also. Now he's peed as he bough a new set on advice of another builder. Make him a offer of a little less than 40% and see what happens(this based on how they look)
[Re: cudaman1969]
#2466780
03/15/18 07:04 AM
03/15/18 07:04 AM
LSP
Charlotte, NC
I would say all if not all NASCAR engine builders turn their own pistons. No, the only team turning any pistons is Hendrick.
[Re: rowin4]
#2468415
03/19/18 12:43 AM
03/19/18 12:43 AM
Posts: 132 Kingman, Az
Scojodak
Kingman, Az
Fellaz, what about the ring fitment. Won't the inside diameter of the ring pinch the piston inner groove?
Dakota for life!
[Re: MR_P_BODY]
#2468434
03/19/18 01:45 AM
03/19/18 01:45 AM
rowin4
I talked to a engine builder and had him look at them, he said he'd run them as is . This of coarse changed my game plan of getting a free set of $800. pistons as the owner of them was there also. Now he's peed as he bough a new set on advice of another builder. Make him a offer of a little less than 40% and see what happens(this based on how they look) I talked to him last Wednesday and he said after he thought about what the engine guy said about still being usable , he said he was going to keep them. I'll bring it up once in awhile as he probably won;t ever use them as his block is bored to the next oversize.
