Re: CM cage
[Re: CMcAllister]
#2464267
03/10/18 01:31 PM
03/10/18 01:31 PM
Posts: 8,357 fredericksburg,va
cudaman1969
fredericksburg,va
Sheet metal is just hanging there, but like my inspector said, you have two cages, body and roll cage. Exactly. The formed sheet metal body is also a stiff and substantial structure. Use it. With some planning, the body and the new chassis/cage can be made to support and reinforce each other, making the assembly stronger than if the body was just along for the ride. Tie them together, beyond the mounting points called for to get the cage in the car, to create one assembly You said it better than me, thanks
Re: CM cage
[Re: polyspheric]
#2464920
03/11/18 08:50 PM
03/11/18 08:50 PM
Posts: 1,467 Martinsville, IN
cdwmotorsports
Martinsville, IN
My point was that when people who weren't interested enough to post correct information assume that no one else has, they're just wasting my time.
My new rule: assume everyone already knows everything, and never makes mistakes. Yup, that'll work. I’m not sure who you are referring to, however I have noted on numerous occasions rather than interject positive helpful replies you post your feelings and then get butt hurt when not everyone agrees with you. My statement is correct, going to a CM cage allows me to use smaller bars, why because I have a MS 10pt cage already. So you assuming you know everything about my car gets old. So please do us all a favor and either start posting useful info or just don’t post. I don’t have time for you getting all butt hurt.
eBay-cdwmotorsports
Re: CM cage
[Re: polyspheric]
#2465067
03/12/18 02:38 AM
03/12/18 02:38 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
My mistake, I didn't realize how important you are. another useless statement.. what's up with the personal attacks..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: CM cage
[Re: WHITEDART]
#2465068
03/12/18 02:44 AM
03/12/18 02:44 AM
Thumperdart
State of confusion
My mistake, I didn't realize how important you are. another useless statement.. what's up with the personal attacks.. Agree, another guy w/no car and who THINKS he's smarter than everyone else..... ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif)
Re: CM cage
[Re: Jeremiah]
#2465303
03/12/18 05:23 PM
03/12/18 05:23 PM
cdwmotorsports
Martinsville, IN
Thanks for the pictures Doug. I appreciate the real world perspective. While theory is nice seeing practical applications in living color really helps and gives me hope that my project will turn out (half) as good.
Oh, and my feeling is also hurt because nobody bowed down and thanked me for my ambiguous post filled with information you didn't ask for lol.
Also, to answer your original question - you can use mild steel 2xwhatever for outriggers and utilize your MIG to tack the CM together and it won't hurt. The TIG process will use mild steel filler rod so it will be compatible for lack of better terms. Jeremiah, your info was useful I’m not sure why you felt as though you should’ve been included.
eBay-cdwmotorsports
Re: CM cage
[Re: dvw]
#2465305
03/12/18 05:26 PM
03/12/18 05:26 PM
cdwmotorsports
Martinsville, IN
Much easier to remove a section of the floor. Weld in the cage and outriggers. Then trim and weld the floor cutouts back in. Doug Doug, I greatly appreciate the pictures. If you could I would like to see pics of how it’s all laid out on the bottom side. I’m pretty sure we put the cross bars from the 2x4 box frame connectors in the floor by the rear seat but I’m almost 100% sure we didn’t do them up front. Headed out to look now.
eBay-cdwmotorsports
Re: CM cage
[Re: cdwmotorsports]
#2465589
03/13/18 12:58 AM
03/13/18 12:58 AM
Posts: 9,105 Rogue River, OR
Jeremiah
Rogue River, OR
Also, to answer your original question - you can use mild steel 2xwhatever for outriggers and utilize your MIG to tack the CM together and it won't hurt. The TIG process will use mild steel filler rod so it will be compatible for lack of better terms. Jeremiah, your info was useful I’m not sure why you felt as though you should’ve been included. I'm just messing with you buddy lol. Please take my middle comment with much sarcasm.
Re: CM cage
#2465815
03/13/18 03:25 PM
03/13/18 03:25 PM
Posts: 11,743 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
As long as the driver is inside of that 1.625 cage, they aren't fussy about fit when it comes to cert. Take the time to get the bars fitted out and up close to the doors and body, out of the line of sight out the windshield, etc. When you can't see the tree because of the A pillar bar, or don't fit in the car, it's too late once it's welded.
Re: CM cage
[Re: FastmOp]
#2465882
03/13/18 05:13 PM
03/13/18 05:13 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
After 44 years of racing and having cars certified to 7.50 I finally made the big time and have a chrome moly cage in one. Who knows what’s next for me.
Re: CM cage
[Re: FastmOp]
#2465956
03/13/18 07:24 PM
03/13/18 07:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'd have the bars come back along the top of the door then have them bend in at the hoop I like to keep all the bars as straight as possible so a slight angle at the main hoop will get you out to where you need at the A pillar.. straight bars are stronger
