Re: Cold air inlet [Re: firefighter3931] #2464472
03/10/18 09:51 PM
03/10/18 09:51 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Hey Ron, here is the underside of my 1970 Road Runner cowl hood LOL smile
Re: Cold air inlet [Re: firefighter3931] #2464475
03/10/18 09:56 PM
03/10/18 09:56 PM
Is there any way to route the inlet tubes from the front of the radiator support down low on both sides to their air cleaner? scope
If so that would supply some cool air pressure and very little debris into the tubes like might occur from the inlet mounted into the tire wells work
Re: Cold air inlet [Re: Cab_Burge] #2464478
03/10/18 10:09 PM
03/10/18 10:09 PM
jersey
Spaceman Spiff Offline
jersey
https://www.ebay.com/itm/1968-Oldsmobile...r-/272069977980
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Cold air inlet [Re: Spaceman Spiff] #2464702
03/11/18 01:11 PM
03/11/18 01:11 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
current setup
Re: Cold air inlet [Re: mkdart] #2464708
03/11/18 01:21 PM
03/11/18 01:21 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
old setup, duct work through fender to radiator core support next to headlight.
Re: Cold air inlet [Re: mkdart] #2464726
03/11/18 01:41 PM
03/11/18 01:41 PM
moparx Offline
moparx  Offline
Originally Posted By mkdart
current setup
VERY nice ! up
beer
Re: Cold air inlet [Re: StealthWedge67] #2464878
03/11/18 07:38 PM
03/11/18 07:38 PM
jersey
jersey
Originally Posted By StealthWedge67
I use a ramairbox setup. Mine pulls through some holes I cut in the core support. I thought about the same location you are thinking of. I tried to fab the hoses off those locations, just couldn’t do it. To tight and odd angles to deal with. Perhaps you’re better than I at fabrication. I think it could be a decent place to pull from except in the rain. Let us know how it works out. Here’s mine:
What degree separation is that? I’ve been thinking of this for my wagon.
