Re: Which street drag tires?
[Re: ScottSmith_Harms]
#2461707
03/05/18 10:17 PM
03/05/18 10:17 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
I run QTP’s on both my cars. Had them on the dart also when it had a 4 speed. They worked well.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: scatpacktom]
#2461709
03/05/18 10:20 PM
03/05/18 10:20 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
A buddy of mine built a '87 notch mustang with a grand national engine. Flat hood, stock interior, other than a few gauges and steering wheel, stock seats, and shifter, no cage or bar. Just had welded in subframe connectors, the kind that you cut the floor for. Stock suspension. With the grand national engine and trans, 3.73's and a set of McCreary ( american racer ) L60-15's that car went 9.72@142, driven to the track, and it still got almost 30 mpg on the hiway. That car made us A LOT of money. And those tires worked great.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
#2461792
03/06/18 12:41 AM
03/06/18 12:41 AM
Posts: 16,517 On the run…
BloFish
On the run…
I recommend tubes with the QTP’s.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
#2461841
03/06/18 01:58 AM
03/06/18 01:58 AM
Posts: 3,103 Phila Pa
scatpacktom
Phila Pa
I've heard of a 69 Dart going on it's roof on a warm sunny day where some water washed across the road in a low spot.
[Re: 4mopower]
#2463190
03/08/18 05:31 PM
03/08/18 05:31 PM
Posts: 4,457 Washington
madscientist
Washington
Has anyone tried the M&H Racemaster? The DOT street version has more tread then the M/T does. I was looking to give these a try. I use them. Been using them on this car since 2004. Due for a new set and I'm going to replace them with the same tire.
[Re: B3422W5]
#2463977
03/09/18 08:42 PM
03/09/18 08:42 PM
Posts: 5,345 Planet Earth
RoadRunnerLuva
Planet Earth
Thanks guys....I never even thought of QTP's (or American racer L60-15's for that matter). Question, while checking into the QTP's they are pretty adamant about saying "For Off Road Use Only", obviously they are a thinly disguised drag slick but are they truly unsafe on the street (wet roadways aside)? The MT and AR's don't offer such harsh warnings as far as I am aware? I have driven hundreds and hundreds of street miles on QTP’s nice tires The 28 by 11.5( 28 by 10 wide) fits nicely on a Demon/ Duster with correct backspace wheel. What size rear wheel and backspace, would work best on a Demon/Duster with the above mentioned QTP tire?? I have a stock width 8-3/4 with a 4.10 and automatic, and stock leaf spring location. I was thinking of using these tires too??
Plymouth Makes It!
[Re: B3422W5]
#2464456
03/10/18 08:49 PM
03/10/18 08:49 PM
Posts: 2,070 Taylor, Michigan
1BadLiLCharger
Taylor, Michigan
I have driven hundreds and hundreds of street miles on QTP’s nice tires The 28 by 11.5( 28 by 10 wide) fits nicely on a Demon/ Duster with correct backspace wheel. Same ones I use at the strip for my Mustang, Don. That tread depth scared me, so I also have a set of 295/55/15 M/T ET Street S/S that I use for the street.
[Re: 1BadLiLCharger]
#2464459
03/10/18 09:01 PM
03/10/18 09:01 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
I have driven hundreds and hundreds of street miles on QTP’s nice tires The 28 by 11.5( 28 by 10 wide) fits nicely on a Demon/ Duster with correct backspace wheel. Same ones I use at the strip for my Mustang, Don. That tread depth scared me, so I also have a set of 295/55/15 M/T ET Street S/S that I use for the street. Good to see you posting Pat
#2464518
03/11/18 12:04 AM
03/11/18 12:04 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I have driven hundreds and hundreds of street miles on QTP’s nice tires The 28 by 11.5( 28 by 10 wide) fits nicely on a Demon/ Duster with correct backspace wheel. What offset/backspace are your wheels? Stock axle width?
[Re: weedburner]
#2464545
03/11/18 01:27 AM
03/11/18 01:27 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Radials with a 4spd is easier than you might think, likely quicker/faster and better mpg as well. Please elaborate.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: mopar873]
#2464591
03/11/18 03:58 AM
03/11/18 03:58 AM
Posts: 43,271 Bend,OR USA
Cab_Burge
Yes, I would like to hear how it's easy as well. I spent years trying to hook a radial on a pretty nasty 6spd Fbody GM...going against other racer's advice in the process. When I finally did switch to ET Drag Bias Plys, my 60ft dropped 2 tenths immediately. More importantly it stayed consistent. When trying to launch a manual, track prep, pressure, and suspension are a magical combination. And, that combination usually only works on that track on that day. No doubt, they have the potential to go faster, but save yourself the headaches and run bias plys. I've bracket raced more than one 4 speed car when I was a lot younger and willing to do the maintenance needed to do that, no more My last halfway fast(9.99 in the 1/4 cork up through the air cleaner with full exhaust N/A ) pump gas street car with a good converter and a 727 tranny would get real ugly in a heartbeat at speeds above 55 MPH when I went to WOT on a less than perfect surface road on M/T ET Street Radials, not so on the same size ET Street bias plys Trust me on this, don't get hurt trying to make a radial hook up on a high HP street car under normal driving conditions unless their real big and wide
#2464631
03/11/18 10:24 AM
03/11/18 10:24 AM
B3422W5
Portage,michigan
Dang, you had to ask me lol. Yes stock axles. I honestly dont remember if it was 4.5 or 5.5 backspace. i will ask some buddies who have done the same thing, i am pretty sure 4.5 but dont want to swear to it
#2464694
03/11/18 01:03 PM
03/11/18 01:03 PM
Posts: 12,591 Great Neck,LI,new york
hemi-itis
I am curious if ANY of you with over 500 HP can hook from a dead stop??? I have ET Street R's bias and I cant hook down low whatsoever.I av roll out in 1st and short shift 2nd then roll into it hard so 2/3s of the way through 2nd I'm at WOT then click high and stay hooked,,,most of the time. Also use 31 X 16.5's. Ay the track I use 10.5w M\T and they work very good
