Cold air inlet #2461018
03/04/18 06:22 PM
03/04/18 06:22 PM
Ontario,Canada
firefighter3931 Offline OP
Ontario,Canada
Thinking of using a Ram air box setup on my 68 Charger with the stock flat hood.
http://www.ramairbox.com/
These air cleaner assemblies are sealed and use 4inch hose. My question centers on the inlet location. I'm thinking of running the inlets into the inner fender where air would be drawn in around the front wheels.
Obviously there is no ram effect but I'm wondering if it would be worth the effort vs the current setup which is a standard 14x3 drop base assembly.
Opinions ? Comments ?
Ron
Re: Cold air inlet [Re: firefighter3931] #2461032
03/04/18 07:08 PM
03/04/18 07:08 PM
jersey
Spaceman Spiff Offline
jersey
how are you going to keep rocks, dirt, leaves, water, etc, out?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Cold air inlet [Re: firefighter3931] #2461281
03/05/18 01:35 AM
03/05/18 01:35 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I use a ramairbox setup. Mine pulls through some holes I cut in the core support. I thought about the same location you are thinking of. I tried to fab the hoses off those locations, just couldn’t do it. To tight and odd angles to deal with. Perhaps you’re better than I at fabrication. I think it could be a decent place to pull from except in the rain. Let us know how it works out. Here’s mine:
Re: Cold air inlet [Re: StealthWedge67] #2461348
03/05/18 05:31 AM
03/05/18 05:31 AM
I like that, it looks good up bow
Re: Cold air inlet [Re: firefighter3931] #2461355
03/05/18 09:00 AM
03/05/18 09:00 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
Very clean and neat. I like the whole car! Any performance gains that you noticed after intall?
Re: Cold air inlet [Re: Hemi ragtop] #2461857
03/06/18 02:33 AM
03/06/18 02:33 AM
Puyallup, WA
Puyallup, WA
Thanks. I did it years ago when the original 383 was still in the car. If I remember correctly, I added it and changed carburetors at the same time, so it got faster but I can’t peg how much was this system vs the carb. Probably not much to be honest, but it certainly couldn’t have hurt it. It may be worth more to the current combo, since it is obviously drawing more air than the 383 did.
Regarding the ramairbox purchase, the product is very nicely finished and still looks great years later. Don’t hesitate to buy from them.
Re: Cold air inlet [Re: firefighter3931] #2461968
03/06/18 12:57 PM
03/06/18 12:57 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Ron
If you can the cowl is a better area for air
Universal spinners is Scarborough makes the same type of housing
http://www.universalspinners.com/muscle-car-owners.php
Re: Cold air inlet [Re: The Shadow] #2462077
03/06/18 05:10 PM
03/06/18 05:10 PM
Ontario,Canada
Ontario,Canada
Thanks for the pics and feedback guys !
StealthWedge : that looks great....nice job on the install. Unfortunately in my case I don't have room to go through the core support. My aftermarket radiator has side tanks and is quite wide.
Shadow/Mark : I guess the cowl could work with a cowl scoop ?
I'm trying to keep the stock flat hood and don't like the look of any scoops on a 68-70 Charger hood.
My thinking was drawing ambiant air from the wheelwell area has to be much better than sucking 250* underhood air. My question really centered on how much better would it run and is it worth the expense ?
Ron
Re: Cold air inlet [Re: firefighter3931] #2462359
03/07/18 12:17 AM
03/07/18 12:17 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Ron
as far as 1/4 times I have no data, but after I sealed my air cleaner to my cowl hood the car ran much better on the street, the AFR was much more stable though the range of driving, the butt dyno says it had more power.
Re: Cold air inlet [Re: CSK] #2462545
03/07/18 01:35 PM
03/07/18 01:35 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Spectra makes a kit also I got mine from Summit. I put the set up in my D150 and also put one hole in the radiator support and connected one to the factory ducting which pulls air from under the turn signal. I put a piece of screen in front of the support inlet to keep out bugs, etc.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Cold air inlet [Re: firefighter3931] #2462565
03/07/18 02:11 PM
03/07/18 02:11 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Dizusters turbo car draws from the left inner wheel well. A K&N cone shaped filter is mounted in the wheel well behind the headlamp. One 4" tube/hose feeds 850hp. Street driven with no issue.
Doug
Re: Cold air inlet [Re: firefighter3931] #2462687
03/07/18 05:36 PM
03/07/18 05:36 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Ron, a friend of mine has a super nice (& fast) 65 Coronet 500 with the 17"x 5"setup on his RB 512 stroker with 2x4's. Ducted to the inner headlight buckets with mesh covering the openings. Looks really trick & flows good. I know you can't do that with your Charger's concealed head lights, but Spectra makes a firewall ducted unit that draws air from the vents at the base of the windshield. Similar to what Petty did on his 64 NASCAR Belvedere. I'm considering that with my 64 Belvedere. BTW, glad to see you still have your 68 Charger & would be great to get together with Holly's Charger again. Buzz
Re: Cold air inlet [Re: firefighter3931] #2463355
03/08/18 09:44 PM
03/08/18 09:44 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Ron
you're in a bit of a quandary. Your machine is too nice to be cutting holes for air scoops in the inner fenders ,core support ,hell any place.
The cowl is a option for clean fresh air
Re: Cold air inlet [Re: The Shadow] #2463939
03/09/18 07:57 PM
03/09/18 07:57 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
PM sent
Re: Cold air inlet [Re: CSK] #2464245
03/10/18 12:28 PM
03/10/18 12:28 PM
Ontario,Canada
Ontario,Canada
Originally Posted By csk
As far as 1/4 times I have no data, but after I sealed my air cleaner to my cowl hood the car ran much better on the street, the AFR was much more stable though the range of driving, the butt dyno says it had more power.
Thanks Charlie.....that's what I figured. Stands to reason that a sealed carb to fresh air would show some improvement.
Ron
Re: Cold air inlet [Re: Triggerfish] #2464247
03/10/18 12:34 PM
03/10/18 12:34 PM
Ontario,Canada
Ontario,Canada
Hi Buzz,
Thanks for the info ! That cold air assembly looks effective but wouldn't work on a Charger. The wiper motor is right where that firewall ducting would have to be spliced in. It is still a street car and I need wipers apimp
Does Holly still have the '69....allways loved that car bow
Hope to make it back out to Vegas one of these years....allways a blast ! beer
Ron
Re: Cold air inlet [Re: The Shadow] #2464248
03/10/18 12:40 PM
03/10/18 12:40 PM
Ontario,Canada
Ontario,Canada
Originally Posted By The Shadow
Ron
Hey Mark,
Yep....it's too nice to cut up. I might have to rethink the aftermarket hood deal. A 'Glass hood sealed to the carb would be the least intrusive option (No Hacking)and provide some cool air with the ram effect. The added bonus would be a 50lb weight reduction on the nose. Just have to come up with something I like from an aesthetic standpoint. thumbs
Ron
Re: Cold air inlet [Re: firefighter3931] #2464323
03/10/18 03:49 PM
03/10/18 03:49 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Hi Buzz,
Ron
Ron, I bought a one piece fiberglass hood with a 6 Pack scoop for the 69 R/T SE I had & gave it to Holly for his 69. Its stuffed away in his shed & he'll never use it with his Hemi, so if you're interested, I'll ask him if he wants to part with it. Landy used the earlier Hemi scoop on his Charger, but the 6 pack may work better since it sits higher. Here's one on a 68 from google images.
Re: Cold air inlet [Re: firefighter3931] #2464349
03/10/18 04:58 PM
03/10/18 04:58 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
The 2nd gen Charger is a difficult one for a hood scoop, the stock hood looks the best, for me the cowl hood looks better on a Charger than other scoops.
Re: Cold air inlet [Re: firefighter3931] #2464389
03/10/18 06:18 PM
03/10/18 06:18 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
Ron, your hood scoop is similar to mine. How do you like the ram air box I made for my 66'?
