OEM Electrical connection and tools
#2463025
03/08/18 11:57 AM
03/08/18 11:57 AM
Posts: 6,393 Abilene, Texas
fastmark
Abilene, Texas
I need to repair some wiring harnesses and they have tools on eBay ranging from $4 to $400 to remove the terminals from the plastic connectors. The spades are easy but I need to remove some of the round ones in the ignition harness. I would also like to know where you can buy the factory style brass connectors. Anyone bought these that can give advice? Any thoughts on where you can buy the correct colored wires? Especially the ones with the tracer color. Thanks
Re: OEM Electrical connection and tools
[Re: fastmark]
#2463053
03/08/18 01:02 PM
03/08/18 01:02 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I have a set of tools from Packard that my brother had.He had like 20 sets at one time and sold a bunch on Ebay.They were toss outs as new stuff came out.They work great on almost all connectors.They do come up on Ebay at times from a few bucks to 40 or 50 depending on how many in a set.IIRC one company makes OE type connectors.I used to use some small scredrivers etc at work before i got my OE type tools.Rocky
Chrysler Firepower
[Re: fastmark]
#2463069
03/08/18 01:31 PM
03/08/18 01:31 PM
RapidRobert
I would also like to know where you can buy the factory style brass connectors. Any thoughts on where you can buy the correct colored wires? Especially the ones with the tracer color. Thanks NAPA has the common "packard 56" type male female terminals for the bulkhead 725145/725147 but they are pricey (99 cents ea). there are companies that sell em in bulk for way less (eBay likely). Yes you absolutely want to keep the same colors as OE including colors with tracers & there are companies out there who sell specific lengths of em & on some circuits you may want to go larger (as you know a smaller gauge). I dont have a specific company(s) but you might Google it.
[Re: therocks]
#2463175
03/08/18 04:59 PM
03/08/18 04:59 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I have a set of tools from Packard that my brother had.He had like 20 sets at one time and sold a bunch on Ebay.They were toss outs as new stuff came out.They work great on almost all connectors.They do come up on Ebay at times from a few bucks to 40 or 50 depending on how many in a set.IIRC one company makes OE type connectors.I used to use some small scredrivers etc at work before i got my OE type tools.Rocky i've always used jewelers screwdrivers to pop them apart. dollar stores usually has them or drug stores where they sell cheap reading glasses.
[Re: fastmark]
#2463268
03/08/18 07:14 PM
03/08/18 07:14 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Try Terminal Supply Co - they have several locations, plus I-net sales. Also Lectric Limited has a website. I've had good success with both.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: fastmark]
#2463301
03/08/18 08:16 PM
03/08/18 08:16 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Adding on to what others have said. The Terminal styles are Packard 56. If you find some are larger, they are probably Packard 58 or 59. Crib sheet to ID all sorts of automotive terminals & connectors: http://www.rowand.net/shop/tech/automotiveelectricalconnectors.htmTools:The crimpers needed are for "open barrel" terminals from 18 to at least 12, preferably 10 or 8 gage. The larger gages can come into use with smaller wires when joining two at a terminal. For example at the ballast resistor. * American Autowire sells a set of proper crimpers, slightly less expensive than the real thing. * Astro sells a nice compound action crimper but the jaws are too wide for the male terminals. The little wings at the bottom of the terminals (seen below) are in the way. Terminal removal tool. Seems silly when a cotter pin or small screw driver will do, but they do save time and minimize damage. I think they are worth it. Best in use is the single prong version. Multi-prongs sometimes interfere with the adjacent terminal cavities. MaterialsWire: My preference is from a marine supply center. Slightly more copper for any given gage size, tinned surface, and insulation suitable for engine compartments. They also have a ton of colors and can cut what you need. Second preference for engine compartment is wire with insulation for that environment (heat and oil) such as GXL or (IIRC) THWN rated insulation. Otherwise GPT (general purpose primary) is fine. eg https://www.wirebarn.com/Wire-Selection-Guide-_ep_29.htmlAnother source for colored & trace marked wire: Rhode Island Wire http://www.riwire.com/Terminals Sources:Waytek Wire 56 series are catagorized under metripack here Del City Del City Terminal Supply Co. Repair Connector store Electrical Depot I found with my jeep, which also used a lot Packard 56 type connectors, not all the terminals were like the original. Not just whether they had a tin plate, but the shoulder stops and lengths varied on some of the replacments. The one on the far left lacks the little wings at the bottom. How important is that?
[Re: Evil Spirit]
#2463307
03/08/18 08:31 PM
03/08/18 08:31 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Try Terminal Supply Co - they have several locations, plus I-net sales. Also Lectric Limited has a website. I've had good success with both. Terminal Supply Co. was awesome to deal with. They don't mind working with hobbyists, so you can order just one or two terminals where everyone else wants to sell them 25count at a time. They'll have both the packard 56 tools and the round ones.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: 1971 Gran Coupe]
#2463608
03/09/18 10:47 AM
03/09/18 10:47 AM
fastmark
Abilene, Texas
When I ordered some of the Packard connectors they included a catalog with what they have. It is amazing how many different wire terminals they carry. What company did you get you catalog from? I found the American wire website and found out the one mostly used appears to be the Packard 56. I still have not found the round ones like go in the ignition and turn signal switch. I have not searched for wire yet. Thanks guys. This will help. I’ll get digging on the net. 👍👍
[Re: fastmark]
#2463636
03/09/18 11:48 AM
03/09/18 11:48 AM
RapidRobert
If you order anything however small (but Mopar specific) from www.classicindustries.com online then in several weeks their comprehensive $12.95 Mopar catalogue will arrive unexpectedly in your mailbox for free & it is a treasure trove of pics of many varieties of items including electrical. it is a must have reference manual.
[Re: fastmark]
#2463667
03/09/18 12:33 PM
03/09/18 12:33 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
This thread is very informative,thank you! Handy since I do a lot of mopar rewiring!
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: fastmark]
#2463681
03/09/18 01:05 PM
03/09/18 01:05 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
When I ordered some of the Packard connectors they included a catalog with what they have. It is amazing how many different wire terminals they carry. What company did you get you catalog from? Terminal Supply Co. was awesome to deal with. You actually erased it from the post you quoted.
I have mechanical Aptitude. I can screw up anything.
