Re: Body in white Cuda Challenger????
[Re: MattW]
#2462872
03/07/18 11:18 PM
03/07/18 11:18 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Not sure if amd makes every part, but obviously dynacorn does. I know a lot of people like amd because of the thickness and every dynacorn part I used was thicker than oem like amd. So you may have to use some odds and ends, but it can be done.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: fastmark]
#2463360
03/08/18 09:47 PM
03/08/18 09:47 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
The problem with a complete new body in white would be a vin number problem seems like to me. They are still cars out there than can be repaired with the replacement metal we have out there now and still have a clean title. I have several bodies that fall into that category.just none that are valuable enough to justify a restoration. If you just wanted a shell to resto rod, then a 318 car will work great and not cost you an arm and a leg to start with. That way you would have a car that could be built that not require a large jig to build it on. Just my two cent. But I live in Texas where there are cars that are not falling apart with rust. NOT interested in a restoration numbers matching car. need a rolling chassis. VIN is an easy fix just make it a Hot Rod. DYNACORN is NOT making the challenger anymore. Matt
[Re: Silver70]
#2463650
03/09/18 12:12 PM
03/09/18 12:12 PM
Posts: 10,735 North Dakota
6PakBee
North Dakota
All you need to use the vin of an existing car is to use the a pillars and cowl of an original... not sure the exact dimension, but is a legal way to do it. That's basically what Fantomworks did to that '57 Chevy replacement body. I can't remember the details exactly but as I remember they just used the pillar with the existing VIN.
[Re: 6PakBee]
#2464032
03/09/18 09:37 PM
03/09/18 09:37 PM
Posts: 18,157 Mass
DAYCLONA
Mass
All you need to use the vin of an existing car is to use the a pillars and cowl of an original... not sure the exact dimension, but is a legal way to do it. That's basically what Fantomworks did to that '57 Chevy replacement body. I can't remember the details exactly but as I remember they just used the pillar with the existing VIN. A pillars and upper cowl section, the whole section has to be at least 22" in overall width minimum as per Federal guidelines when transplanting your donor VIN into the "replacement body"...
