Re: Bushed lifter bore question [Re: varunner] #2463824
03/09/18 04:09 PM
03/09/18 04:09 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Am I missing something?
The entire gallery on each bank is oiled from one end. The tappets communicate oil flow through to the gallery on the other side, and to the next tappet.
Unless all the bushings are drilled on both sides, only the first tappet in each gallery will get any oil.
I've seen C932 (SAE 660) bronze recommended, is there a better choice?
Boffin Emeritus
Re: Bushed lifter bore question [Re: varunner] #2463839
03/09/18 04:41 PM
03/09/18 04:41 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
The lifter galley is drilled at a tangent with a large hole, unless you do something like 1" fuel lifter bushings, there's still an uninterrupted oil path.
The bushings we use are some ampco material, 15 I think. S/F....Ken M
Re: Bushed lifter bore question [Re: varunner] #2464136
03/10/18 02:09 AM
03/10/18 02:09 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Makes more sense, thanks.
Boffin Emeritus
