Page 2 of 3 1 2 3
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461707
03/05/18 10:17 PM
03/05/18 10:17 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I run QTP’s on both my cars. Had them on the dart also when it had a 4 speed. They worked well.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Which street drag tires? [Re: scatpacktom] #2461709
03/05/18 10:20 PM
03/05/18 10:20 PM
jersey
Spaceman Spiff Offline
jersey
Originally Posted By scatpacktom
American racer L60-15
A buddy of mine built a '87 notch mustang with a grand national engine. Flat hood, stock interior, other than a few gauges and steering wheel, stock seats, and shifter, no cage or bar. Just had welded in subframe connectors, the kind that you cut the floor for. Stock suspension. With the grand national engine and trans, 3.73's and a set of McCreary ( american racer ) L60-15's that car went 9.72@142, driven to the track, and it still got almost 30 mpg on the hiway.
That car made us A LOT of money. And those tires worked great.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461753
03/05/18 11:39 PM
03/05/18 11:39 PM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
M & H 275-60-15 bias plys. On my third set. Drive more than race, but 3800 # car went 1.52 on them through the pipes.
Lots of buddies run American Racers too. AR is less $$ than the M & H.
Re: Which street drag tires? [Re: Tommy D] #2461782
03/06/18 12:27 AM
03/06/18 12:27 AM
fullmetaljacket Offline
Driven many miles with QTP's. Just stay out of water and rain or slow down extremely . They are wrinkle wall types with the right pressure.
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461792
03/06/18 12:41 AM
03/06/18 12:41 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I recommend tubes with the QTP’s.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461820
03/06/18 01:19 AM
03/06/18 01:19 AM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
I hear you on the wet roads part, I've been caught out in some rain with the MT drag radials and even those were a little spooky. drive
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461841
03/06/18 01:58 AM
03/06/18 01:58 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I've heard of a 69 Dart going on it's roof on a warm sunny day where some water washed across the road in a low spot.
Re: Which street drag tires? [Re: scatpacktom] #2461849
03/06/18 02:20 AM
03/06/18 02:20 AM
My boy Curt did a Ballerina dance with his Duster and kissed the wall on the BQE coming from the now defunct E-town in light rain against my wishes while wearing M/T ET streets. I had told him to slow her down, and whali-whoop, it all happened right in front of me.
QTP's are no better.
I always keep a keen eye for puddles, open hydrants and just lay low if rain catches me out there.
On dry pavement, they are chiclee as they say in Spanish as Chewing gum.
Re: Which street drag tires? [Re: ScottSmith_Harms] #2463153
03/08/18 04:22 PM
03/08/18 04:22 PM
Chicago-area Illinois
4mopower Offline
4mopower  Offline
Has anyone tried the M&H Racemaster?
The DOT street version has more tread then the M/T does.
I was looking to give these a try.
Re: Which street drag tires? [Re: 4mopower] #2463190
03/08/18 05:31 PM
03/08/18 05:31 PM
Washington
madscientist Offline
Washington
I use them. Been using them on this car since 2004. Due for a new set and I'm going to replace them with the same tire.
Re: Which street drag tires? [Re: ScottSmith_Harms] #2463936
03/09/18 07:50 PM
03/09/18 07:50 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I want to put the American racers on my dart. I really like the look, I remember lots of guys running them when I was a kid. I want something more streetable that an ET street.
Re: Which street drag tires? [Re: B3422W5] #2463977
03/09/18 08:42 PM
03/09/18 08:42 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
Originally Posted By B3422W5
Originally Posted By ScottSmith_Harms
Thanks guys....I never even thought of QTP's (or American racer L60-15's for that matter). Question, while checking into the QTP's they are pretty adamant about saying "For Off Road Use Only", obviously they are a thinly disguised drag slick but are they truly unsafe on the street (wet roadways aside)? The MT and AR's don't offer such harsh warnings as far as I am aware?
I have driven hundreds and hundreds of street miles on QTP’s nice tires
The 28 by 11.5( 28 by 10 wide) fits nicely on a Demon/ Duster with correct backspace wheel.
What size rear wheel and backspace, would work best on a Demon/Duster
with the above mentioned QTP tire?? I have a stock width 8-3/4 with a
4.10 and automatic, and stock leaf spring location. I was thinking of using these tires too?? work
Plymouth Makes It!
Re: Which street drag tires? [Re: B3422W5] #2464456
03/10/18 08:49 PM
03/10/18 08:49 PM
Taylor, Michigan
1BadLiLCharger Offline
Taylor, Michigan
Same ones I use at the strip for my Mustang, Don. That tread depth scared me, so I also have a set of 295/55/15 M/T ET Street S/S that I use for the street.
Re: Which street drag tires? [Re: 1BadLiLCharger] #2464459
03/10/18 09:01 PM
03/10/18 09:01 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Good to see you posting Pat
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Which street drag tires? [Re: ScottSmith_Harms] #2464518
03/11/18 12:04 AM
03/11/18 12:04 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
What offset/backspace are your wheels? Stock axle width?
Re: Which street drag tires? [Re: weedburner] #2464545
03/11/18 01:27 AM
03/11/18 01:27 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Originally Posted By weedburner
Radials with a 4spd is easier than you might think, likely quicker/faster and better mpg as well.
Please elaborate.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Which street drag tires? [Re: OhioMopar] #2464554
03/11/18 01:50 AM
03/11/18 01:50 AM
WI
mopar873 Offline
mopar873  Offline
WI
Yes, I would like to hear how it's easy as well. I spent years trying to hook a radial on a pretty nasty 6spd Fbody GM...going against other racer's advice in the process. When I finally did switch to ET Drag Bias Plys, my 60ft dropped 2 tenths immediately. More importantly it stayed consistent. When trying to launch a manual, track prep, pressure, and suspension are a magical combination. And, that combination usually only works on that track on that day. No doubt, they have the potential to go faster, but save yourself the headaches and run bias plys.
Re: Which street drag tires? [Re: mopar873] #2464591
03/11/18 03:58 AM
03/11/18 03:58 AM
Cab_Burge Online work
Cab_Burge  Online Work
iagree up
I've bracket raced more than one 4 speed car when I was a lot younger and willing to do the maintenance needed to do that, no more down
My last halfway fast(9.99 in the 1/4 cork up through the air cleaner with full exhaust N/A boogie) pump gas street car with a good converter and a 727 tranny would get real ugly in a heartbeat at speeds above 55 MPH when I went to WOT on a less than perfect surface road on M/T ET Street Radials, not so on the same size ET Street bias plys work
Trust me on this, don't get hurt trying to make a radial hook up on a high HP street car under normal driving conditions unless their real big and wide work
Re: Which street drag tires? [Re: ScottSmith_Harms] #2464631
03/11/18 10:24 AM
03/11/18 10:24 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Dang, you had to ask me lol. Yes stock axles. I honestly dont remember if it was 4.5 or 5.5 backspace. i will ask some buddies who have done the same thing, i am pretty sure 4.5 but dont want to swear to it
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Which street drag tires? [Re: ScottSmith_Harms] #2464694
03/11/18 01:03 PM
03/11/18 01:03 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I am curious if ANY of you with over 500 HP can hook from a dead stop???
I have ET Street R's bias and I cant hook down low whatsoever.I av roll out in 1st and short shift 2nd then roll into it hard so 2/3s of the way through 2nd I'm at WOT then click high and stay hooked,,,most of the time.
Also use 31 X 16.5's. Ay the track I use 10.5w M\T and they work very good drive shruggy
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Page 2 of 3 1 2 3
