Re: Which street drag tires?
[Re: ScottSmith_Harms]
#2461328
03/05/18 03:38 AM
03/05/18 03:38 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
MT ET Street Radial or if your a bit more serious with the drags go the same but PRO Radial. I would stay away from a ply tire for lots of street driving.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: sr440]
#2461345
03/05/18 05:21 AM
03/05/18 05:21 AM
Posts: 2,468 Sydney,Australia
tex013
Sydney,Australia
If you are running a 4 speed.... forget about using radials. I agree , accepted wisdom backed up by results . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Uncle Barry]
#2461407
03/05/18 12:10 PM
03/05/18 12:10 PM
Posts: 4,694 Wichita
GY3
Wichita
Love my 275 ET Street Pro's!
#2461418
03/05/18 12:34 PM
03/05/18 12:34 PM
Posts: 8,030 Tulsa OK
Bad340fish
Tulsa OK
Mickey Thompson Drag Radial, I have been through a few sets and seldom had a traction problem.
68 Barracuda Formula S 340
#2461647
03/05/18 08:17 PM
03/05/18 08:17 PM
Posts: 11,723 Portage,michigan
B3422W5
Portage,michigan
Thanks guys....I never even thought of QTP's (or American racer L60-15's for that matter). Question, while checking into the QTP's they are pretty adamant about saying "For Off Road Use Only", obviously they are a thinly disguised drag slick but are they truly unsafe on the street (wet roadways aside)? The MT and AR's don't offer such harsh warnings as far as I am aware? I have driven hundreds and hundreds of street miles on QTP’s nice tires The 28 by 11.5( 28 by 10 wide) fits nicely on a Demon/ Duster with correct backspace wheel.
[Re: B3422W5]
#2461662
03/05/18 09:03 PM
03/05/18 09:03 PM
Thumperdart
State of confusion
Me too and I'd put tubes in em cos the sidewalls are thin and my mid 9-second Dart kills em...........
