Re: Home cage install pics
#246150
03/09/09 09:54 AM
03/09/09 09:54 AM
the posts that go through the package tray are attached a few inches inside of where the halo meets the main hoop. I did this so it would e a straight shot down to where they weld to the trunk floor. The shin clearance realy isnt that bad, it is padded there now however. the driver area room isnt realy as obstructed as the pics make it look. for instance, in one pic it looks like the glove box door wont open, but it operates normaly.
[Re: blownzoom440]
#246151
03/09/09 10:17 AM
03/09/09 10:17 AM
AHHH!! THE REAR SEAT. I've been waiting for that ?? You can't actualy sit in it,but it looks way better with it in dosnt it.
I cut the seat frame i a couple spots so I could bend, twist , and fold it, to get it in place. remarkably it pops right back to its normal shape once you stuff it in to place. some time I'll paint it,I don't realy know with what yet. It's been in the car for a few years now and has not rusted any more than right after I installed it. the mill scale on the tubing definately will not corode.
any ideas on how to paint it well with the interior in?? as for gussets around the rest of the cage, to speak the truth I wanted to, but I got worn out on the project. I know it's strong enough already.
#246152
03/09/09 10:26 AM
03/09/09 10:26 AM
heres a pic of my elephant ear and homemade mount.over built as well.
#246153
03/09/09 10:39 AM
03/09/09 10:39 AM
the tech guys had no problems wth the design, I followed all specs. here is the car at cicero drag strip in syracuse ny.
[Re: racerbychoice]
#246155
03/09/09 11:46 AM
03/09/09 11:46 AM
the door bar passes half way between the elow and shoulder. I believe thats what the spec is. In oder to not cut the dash,the driver A pillar bar was installed upside down and backwards on the passenger side and vise versa.this left a situation were the drive compartment had an angle coming in at it,(if you get my discription). thus the need for the kicker tube straight up by your foot and all the gussets(kinda batman looking,but better than straight chunks of plate.) (My main goal was to have a strong cage, but not loose any factory interior design, wich was accomplished.) also the dash headliner, and windsheild were still installed at the time. I knew this was unorthadox and strange, thus the presentation of my post. and yes the pics make it look bulkier than real life.
