Re: What rearend for turbo car?
[Re: moparmafia]
#2461350
03/05/18 07:16 AM
03/05/18 07:16 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
The dana being referred to is actually a 71. No real good parts available for it.
I would (and have) gone with the strange ultra case. The standard ultra case takes a true 9” gear, but the pinion shaft can be upgraded to a large 35 spline configuration. This particular setup will allow down to a 3.40 ratio. If you upgrade to the 9.5” gear set, you can get a ratio as low as 3.2. These are pro gear sets. Running low ratios is extremely hard on everything in front of the rear end. Plan on spending a whole lot on trans parts.
[Re: TRENDZ]
#2461578
03/05/18 05:38 PM
03/05/18 05:38 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
I would (and have) gone with the strange ultra case. The standard ultra case takes a true 9” gear, but the pinion shaft can be upgraded to a large 35 spline configuration. This particular setup will allow down to a 3.40 ratio. If you upgrade to the 9.5” gear set, you can get a ratio as low as 3.2. These are pro gear sets. Running low ratios is extremely hard on everything in front of the rear end. Plan on spending a whole lot on trans parts. Dana makes the 61,71 and maybe even the 81 series with the 3.54 and higher sped ratios. The 61 first came in the Ford 3/4 ton trucks with a 3.30 ratio, later in the Dodge pickup CTD trucks as already mention with the 3.30 and 3.07 One of the local scrap yards has both, maybe I should scoop both of them up for future builds
[Re: moparmafia]
#2461592
03/05/18 06:00 PM
03/05/18 06:00 PM
TRENDZ
Milwaukee WI
The only CTDs that had a 61 axle were the “W” (4wd) and they were front axles. All pre overdrive CTDs had rear 71s otherwise known as D70U. The only difference from a standard 70 was an internal “U”ndercut for the large pinion gear tooth clearance. Not a good rear for performance by any means. The reason I know this is I have seen more than my fair share, and had to source parts for them.😉
[Re: TRENDZ]
#2461665
03/05/18 09:07 PM
03/05/18 09:07 PM
Cab_Burge
Me thinks your confusing the Dana 60-2(they have the 60-2 cast into the housing above the pinion shaft ) 4x4 front ends with the Dana 70, some of the later 3500 CTD trucks came with some version of Dana 70 up front and Dana 80 in the back I'm going to do some research on those 61 carriers to see if they will accept the Dana 60 35 spline clutch type posi internals
[Re: Cab_Burge]
#2461669
03/05/18 09:11 PM
03/05/18 09:11 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Is Dana really Mopar or are you confused. Lmao.
[Re: moparmafia]
#2461675
03/05/18 09:20 PM
03/05/18 09:20 PM
TRENDZ
Milwaukee WI
Yes. Do some research. As previously stated, all pre overdrive CTD trucks had 70U/71 rear axles. The only exception is the very rare 4:XX to 5:13 dana 70 in military lot tugs.
[Re: pittsburghracer]
#2461682
03/05/18 09:30 PM
03/05/18 09:30 PM
Cab_Burge
Is Dana really Mopar or are you confused. Lmao. Touche, Essay You be right Bro , Dana makes all of their parts for who ever wants to buy enough of them to warrant dealing with those companies.
